- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Install and configure Istio service mesh or OpenShift Service Mesh for Automation Suite networking.
If you grant the Automation Suite installer cluster-admin privileges - or the required write permissions together with the required cluster roles - the installer configures Istio and installs the WASM plugin for routing automatically. In that case, you can skip Step 2: Configuring Istio and installing the WASM plugin for routing and Step 3: Configuring Istio for multiple installations in a single cluster. Perform these steps manually only if you cannot grant the installer those privileges.
Automation Suite requires the Istio service mesh for ingress and networking.
Red Hat provides OpenShift Service Mesh, which relies on Istio internally.
The service mesh installation and configuration is a multi-step process. Which of the steps you must perform depends on whether or not you can grant the Automation Suite installer admin privileges over your cluster. For details, refer to the following table:
| Step | Admin privileges | No admin privileges |
| Step 1: Installing the service mesh | Required | Required |
| Step 2: Configuring Istio and installing the WASM plugin for routing | Not required | Required |
| Step 3: Configuring Istio for multiple installations in a single cluster | Not required | Required |
Before selecting an installation procedure, review the OpenShift Service Mesh compatibility matrix to confirm which OSSM versions are supported for your Automation Suite on OpenShift version.
To install OpenShift Service Mesh, refer to the procedure that applies to the version you use:
Automation Suite does not require applications such as Kiali and Jaeger. However, you can use them at your discretion.
UiPath® has no opinion on configuring the Service Mesh Operator to run on any node.
Installing OpenShift Service Mesh 2.x
To install OpenShift Service Mesh 2.x, follow the instructions in the OpenShift Service Mesh documentation.
To create the OpenShift Service Mesh Control Plane, follow the instructions in the OpenShift Service Mesh Control Plane documentation. Make sure that you also take the following steps:
Install the new instance of the service mesh control plane in the
<istio-system>namespace. -
Use
ClusterWidemode for the service mesh control plane. ForMultiTenantmode, refer to point 3 on this page. The following block must be present under thespecsection of theServiceMeshControlPlaneresource:gateways: enabled: true openshiftRoute: enabled: true mode: ClusterWidegateways: enabled: true openshiftRoute: enabled: true mode: ClusterWideTo disable the OpenShift route, refer to point 4 on this page.
You can use
MultiTenantmode for the service mesh control plane. This scenario requires you to explicitly create a service mesh member roll, as shown in the following sample:apiVersion: maistra.io/v1 kind: ServiceMeshMemberRoll metadata: name: default namespace: <istio-system> spec: members: - <uipath>apiVersion: maistra.io/v1 kind: ServiceMeshMemberRoll metadata: name: default namespace: <istio-system> spec: members: - <uipath> -
You also have the option to disable the OpenShift route. However, this choice comes with the additional responsibility of manually creating a route for the FQDN. For manual route creation, refer to the following sample:
kind: Route apiVersion: route.openshift.io/v1 metadata: name: uipath-route namespace: <istio-system> labels: app: istio-ingressgateway app.kubernetes.io/part-of: istio app.kubernetes.io/instance: <istio-system> maistra.io/owner-name: basic release: istio app.kubernetes.io/version: 2.6.1-1-1 app.kubernetes.io/component: istio-ingress maistra-version: 2.6.1 istio: ingressgateway app.kubernetes.io/managed-by: maistra-istio-operator maistra.io/owner: <istio-system> istio.io/rev: basic app.kubernetes.io/name: istio-ingress spec: to: kind: Service name: istio-ingressgateway tls: termination: passthrough insecureEdgeTerminationPolicy: Redirect host: <fqdn> port: targetPort: https alternateBackends: []kind: Route apiVersion: route.openshift.io/v1 metadata: name: uipath-route namespace: <istio-system> labels: app: istio-ingressgateway app.kubernetes.io/part-of: istio app.kubernetes.io/instance: <istio-system> maistra.io/owner-name: basic release: istio app.kubernetes.io/version: 2.6.1-1-1 app.kubernetes.io/component: istio-ingress maistra-version: 2.6.1 istio: ingressgateway app.kubernetes.io/managed-by: maistra-istio-operator maistra.io/owner: <istio-system> istio.io/rev: basic app.kubernetes.io/name: istio-ingress spec: to: kind: Service name: istio-ingressgateway tls: termination: passthrough insecureEdgeTerminationPolicy: Redirect host: <fqdn> port: targetPort: https alternateBackends: []Warning:Disabling the OpenShift route will lead to the following error when running the prerequisite checks:
❌ [ISTIO_SERVICEMESH_VALIDATION_URL_ACCESS] error accessing the url. unexpected status code: 503❌ [ISTIO_SERVICEMESH_VALIDATION_URL_ACCESS] error accessing the url. unexpected status code: 503
Installing a specific version of OpenShift Service Mesh
Use a YAML file to install a specific version of OpenShift Service Mesh (OSSM). The following example file installs OSSM version 2.4.5:
apiVersion: operators.coreos.com/v1alpha1
kind: Subscription
metadata:
namespace: openshift-operators
spec:
channel: stable
installPlanApproval: Manual
source: redhat-operators
sourceNamespace: openshift-marketplace
startingCSV: servicemeshoperator.v2.4.5
kind: Subscription
metadata:
spec:
channel: stable
If you plan to install a different OSSM version, replace servicemeshoperator.v2.4.5 with the correct value for your version in the YAML file. For example, to install OSSM version 2.5.0, enter servicemeshoperator.v2.5.0.
To install OSSM, run the following command:
oc apply -f <yaml>
oc apply -f <yaml>
Replace the <yaml> placeholder in the sample command with the name of your YAML file.
After you install OSSM, you must manually approve the installation.
In the OpenShift console, go to Operators > Installed Operators > Servicemeshoperator > 1 requires approval > Preview Install Plan > Approve.
Installing OpenShift Service Mesh 3.x
Before you install OpenShift Service Mesh 3.x, make sure that:
- Your OpenShift Service Mesh and Automation Suite versions are compatible. For the supported combinations, refer to the Compatibility matrix.
- You have OpenShift cluster administrator permissions.
- You can access the OpenShift web console.
- You have the domain name (FQDN) used for Automation Suite routing.
- You have the OpenShift CLI (
oc) installed on your workstation.
A complete OpenShift Service Mesh 3.x setup for Automation Suite relies on the following components. The Service Mesh Operator does not provision all of them automatically, so make sure each one is present in the cluster before you install Automation Suite:
- Service Mesh Operator - Manages the lifecycle of the service mesh. You install it from OperatorHub.
- Istio control plane - Provides the core control plane and data plane functionality. The operator provisions it after you create the
Istioresource. - Istio CNI plugin - Configures and enforces mesh networking rules. The operator provisions it after you create the
IstioCNIresource. - Ingress gateway - Exposes Automation Suite applications to external traffic. You must deploy it yourself; the operator does not create it automatically.
- Routes - Provide entry points for Automation Suite components and the validation endpoint. You must create these OpenShift
Routeobjects yourself, as described in the steps below.
To install OpenShift Service Mesh 3.x, follow the instructions for installing the operator from OperatorHub by using the OpenShift web console. For details, refer to the OpenShift Service Mesh documentation.
Install Service Mesh Operator from OperatorHub by following the instructions provided in the OpenShift Service Mesh documentation.
Ensure that the ingress gateway includes the correct labels. The labels must match the values that you pass as the gateway selector in the
input.jsonfile. To verify the ingress gateway label, run:oc get pods -l istio=ingressgateway -n <istio-system>oc get pods -l istio=ingressgateway -n <istio-system> -
Create the required routes by using a YAML file. The YAML file must define routes for the main Automation Suite endpoint, the apps endpoint, the insights endpoint, and the validation endpoint. For details, refer to the following examples:
- Automation Suite endpoint:
--- kind: Route apiVersion: route.openshift.io/v1 metadata: name: uipath-route-https namespace: <istio-system> spec: host: <FQDN> to: kind: Service name: istio-ingressgateway # Istio Ingress gateway Service port: targetPort: https tls: termination: passthrough insecureEdgeTerminationPolicy: Redirect--- kind: Route apiVersion: route.openshift.io/v1 metadata: name: uipath-route-https namespace: <istio-system> spec: host: <FQDN> to: kind: Service name: istio-ingressgateway # Istio Ingress gateway Service port: targetPort: https tls: termination: passthrough insecureEdgeTerminationPolicy: Redirect - Apps endpoint:
--- kind: Route apiVersion: route.openshift.io/v1 metadata: name: uipath-route-apps namespace: <istio-system> spec: host: apps.<FQDN> to: kind: Service name: istio-ingressgateway # Istio Ingress gateway Service port: targetPort: https tls: termination: passthrough insecureEdgeTerminationPolicy: Redirect--- kind: Route apiVersion: route.openshift.io/v1 metadata: name: uipath-route-apps namespace: <istio-system> spec: host: apps.<FQDN> to: kind: Service name: istio-ingressgateway # Istio Ingress gateway Service port: targetPort: https tls: termination: passthrough insecureEdgeTerminationPolicy: Redirect - Insights endpoint:
--- kind: Route apiVersion: route.openshift.io/v1 metadata: name: uipath-route-insights namespace: <istio-system> spec: host: insights.<FQDN> to: kind: Service name: istio-ingressgateway # Istio Ingress gateway Service port: targetPort: https tls: termination: passthrough insecureEdgeTerminationPolicy: Redirect--- kind: Route apiVersion: route.openshift.io/v1 metadata: name: uipath-route-insights namespace: <istio-system> spec: host: insights.<FQDN> to: kind: Service name: istio-ingressgateway # Istio Ingress gateway Service port: targetPort: https tls: termination: passthrough insecureEdgeTerminationPolicy: Redirect - validation endpoint:
--- kind: Route apiVersion: route.openshift.io/v1 metadata: name: istio-validation-route namespace: <istio-system> spec: host: istio-validation.<FQDN> # Istio Ingress gateway Service to: kind: Service name: istio-ingressgateway port: targetPort: http2--- kind: Route apiVersion: route.openshift.io/v1 metadata: name: istio-validation-route namespace: <istio-system> spec: host: istio-validation.<FQDN> # Istio Ingress gateway Service to: kind: Service name: istio-ingressgateway port: targetPort: http2
This route is required for the PreReq Run. If missing, OpenShift may return the following error:
❌ [ISTIO_SERVICEMESH_VALIDATION_URL_ACCESS] error accessing the url. unexpected status code: 503 - Automation Suite endpoint:
Apply the route definitions:
oc apply -f routes.yamloc apply -f routes.yaml -
Verify that the routes were created successfully:
oc get routes -n <istio-system>oc get routes -n <istio-system>You should see the following routes:
uipath-route-httpsuipath-route-appsuipath-route-insightsistio-validation-route
If your Istio CR configures
meshConfig.discoverySelectors, label every Automation Suite namespace to match the selector value. For example, if the selector isistio-discovery=enabled:oc label namespace <uipath> istio-discovery=enabled --overwriteoc label namespace <uipath> istio-discovery=enabled --overwriteWithout this label, istiod cannot recognize the namespace as a mesh member or write the
istio-ca-root-certConfigMap into it. Repeat for<uipath>-installer,<uipath>-check,<uipath>-argocd, and any other Automation Suite namespaces.
The validation route is required. If the route is missing, the prerequisite checks fail with:
Migrating from OpenShift Service Mesh 2.x to 3.x
Before starting the migration process, make sure you have installed or upgraded to a supported Automation Suite version. For details, refer to the Compatibily matrix.
To migrate from OpenShift Service Mesh 2.x to 3.x, follow the steps provided in the official Red Hat migration guide.
After completing the migration, review the OpenShift Service Mesh 3.x installation procedure to ensure that all required configuration steps, such as gateway labeling, route creation, and validation endpoint setup, are in place.
Providing the Istio configuration
To provide the Istio configuration, you must set the following parameters in the input.json file:
"ingress": {
"gateway_selector": {
"istio": "ingressgateway"
"ingress_gateway_secret": "istio-ingressgateway-certs",
"namespace": "<istio-system>",
"istio_gateway_service_name": "istio-ingressgateway"
"ingress": {
The following table describes the Istio configuration parameters:
| Parameter | Value |
ingress.gateway_selector.istio | This is the default label used internally by Automation Suite. However, your environment may use a different label for the Istio ingress gateway depending on how the cluster was configured. The default value is ingressgateway. |
ingress.ingress_gateway_secret | The name of the secret that contains the certificate files. The default value is istio-ingressgateway-certs. |
ingress.namespace | The namespace where you have installed the service mesh. |
ingress.istio_gateway_service_name* | The name of the Istio ingress gateway service. The default value is istio-ingressgateway. |
* Available starting from Automation Suite 2.2510.2.
To check the label used by your Istio ingress gateway, run the following command:
oc -n <istio-system> get deploy istio-ingressgateway -o jsonpath="{.spec.selector.matchLabels.istio}"; echo
This step requires admin privileges for installation in the Istio namespace.
There are two ways to perform the installation:
- Option A: If you cannot provide the permissions that the Automation Suite installer requires, then you must perform this step before the Automation Suite installation.
- Option B: During the Automation Suite installation. This method requires the Kubeconfig file that you use during the Automation Suite installation to have the necessary permissions. To review the permissions, refer to the Granting installation permissions section. If you can provide all the necessary permissions, then skip this step.
Prerequisites
Before you configure Istio and install the WASM plugin for routing, you must meet the following prerequisites:
Use a Linux, Windows, or macOS machine with access to the OpenShift Kubernetes API server.
Install the OpenShift CLI client on your machine. For details, refer to Openshift CLI (oc).
Install Helm 3.14 or newer on the machine from which you plan to install the WASM plugin and authenticate Helm to your private registry. To install and authenticate Helm, take the following steps:
Download and install the Helm binaries on your machine. For details, refer to the Helm documentation.
Authenticate Helm to your registry by following the instructions in the Helm documentation. Alternatively, use the following command, replacing the sample values with your actual registry URL and credentials:
helm registry login my.registry.io:443 --username "admin" --password "secret"helm registry login my.registry.io:443 --username "admin" --password "secret"
Configuration and installation
To configure Istio and install the WASM plugin for routing, take the following steps:
Create an
imagepullsecretin the namespace where you installed the service mesh. To create theimagepullsecret, use your typical workflow or take the following steps:registry= <registry_url> #provide the registry where the UiPath images are hosted username= <user_name> #provide the username which will be used for the authentication password= <password> #provide the password which will be used for the authentication namespace= <namespace> #namespace where you want to create a secret oc create secret docker-registry uipathpullsecret --namespace=${namespace} \ --docker-server=${registry} --docker-username=${username} \ --docker-password=${password} --dry-run=client -o yaml \ | oc apply -f -registry= <registry_url> #provide the registry where the UiPath images are hosted username= <user_name> #provide the username which will be used for the authentication password= <password> #provide the password which will be used for the authentication namespace= <namespace> #namespace where you want to create a secret oc create secret docker-registry uipathpullsecret --namespace=${namespace} \ --docker-server=${registry} --docker-username=${username} \ --docker-password=${password} --dry-run=client -o yaml \ | oc apply -f - -
Create the certificate
Secretin the<istio-system>namespace. TheSecretname must match the value ofingress.ingress_gateway_secretin yourinput.json(the default isistio-ingressgateway-certs), and it must contain three keys:tls.crt,tls.key, andca.crt. Theca.crtkey is required when your TLS certificate is signed by a private or self-signed Certificate Authority.The corresponding
ingressblock ininput.jsonis passed as follows:"ingress": { "namespace": "<istio-system>", "gateway_selector": { "istio": "ingressgateway" }, "ingress_gateway_secret": "istio-ingressgateway-certs" }"ingress": { "namespace": "<istio-system>", "gateway_selector": { "istio": "ingressgateway" }, "ingress_gateway_secret": "istio-ingressgateway-certs" }Create the
Secretusing one of the following methods. Replace the placeholder certificate paths and values with your own.- Using
oc(from certificate files):oc create secret generic istio-ingressgateway-certs \ --namespace <istio-system> \ --from-file=tls.crt=<path-to-tls.crt> \ --from-file=tls.key=<path-to-tls.key> \ --from-file=ca.crt=<path-to-ca.crt>oc create secret generic istio-ingressgateway-certs \ --namespace <istio-system> \ --from-file=tls.crt=<path-to-tls.crt> \ --from-file=tls.key=<path-to-tls.key> \ --from-file=ca.crt=<path-to-ca.crt> - Using a YAML manifest (the values are base64-encoded):
apiVersion: v1 kind: Secret metadata: name: istio-ingressgateway-certs namespace: <istio-system> type: Opaque data: tls.crt: <base64-encoded-tls.crt> tls.key: <base64-encoded-tls.key> ca.crt: <base64-encoded-ca.crt>apiVersion: v1 kind: Secret metadata: name: istio-ingressgateway-certs namespace: <istio-system> type: Opaque data: tls.crt: <base64-encoded-tls.crt> tls.key: <base64-encoded-tls.key> ca.crt: <base64-encoded-ca.crt>
- Using
Create a parameter values file to apply during the Helm installation of
istio-configure. Use the following sample as a template for the file and the replace the<fqdn>,<pullsecret>,<registry>, and<uipath_namespace>placeholders with appropriate values:fqdn: <fqdn> #the FQDN of the Automation Suite gateway: selector: istio: ingressgateway global: cluster_type: openshift # REQUIRED kubernetesDistribution: openshift # REQUIRED imagePullSecret: name: <pullsecret> #name of pull secret which you had create earlier minProtocolVersion: TLSV1_2 #TLS versions uipath: registry: <registry> #registry url without the protocol uipathServiceNamespace: <uipath_namespace> #namespace where the uipath application is deployed patchIstioService: false istioGatewayServiceName: "istio-ingressgateway" wasm: image: pullSecret: <pullsecret> #name of pull secret which you had create earlier registry: oci://<registry> #registry url without the protocolfqdn: <fqdn> #the FQDN of the Automation Suite gateway: selector: istio: ingressgateway global: cluster_type: openshift # REQUIRED kubernetesDistribution: openshift # REQUIRED imagePullSecret: name: <pullsecret> #name of pull secret which you had create earlier minProtocolVersion: TLSV1_2 #TLS versions uipath: registry: <registry> #registry url without the protocol uipathServiceNamespace: <uipath_namespace> #namespace where the uipath application is deployed patchIstioService: false istioGatewayServiceName: "istio-ingressgateway" wasm: image: pullSecret: <pullsecret> #name of pull secret which you had create earlier registry: oci://<registry> #registry url without the protocol -
Install
istio-configurein the Istio namespace directly from the OCI registry, using Helm. In the following command, replace the<docker-registry>placeholder with your registry,<istio-configure-version>with the chart version,<istio_namespace>with the namespace where Istio is installed, and<path_to_the_values.yaml>with the location of the parameter values file:helm upgrade --debug --install --wait custom-istio-configure \ oci://<docker-registry>/helm/istio-configure --version <istio-configure-version> \ --namespace <istio_namespace> -f <path_to_the_values.yaml>helm upgrade --debug --install --wait custom-istio-configure \ oci://<docker-registry>/helm/istio-configure --version <istio-configure-version> \ --namespace <istio_namespace> -f <path_to_the_values.yaml>Set
<istio-configure-version>to the version that matches your Automation Suite release. The available versions are2.2510.0,2.2510.1,2.2510.2, and2.2510.3. You can also find the exact value in theversions.jsonfile included with your downloaded installation packages (theistio-configureentry). -
If you use a registry that is not signed by a known authority, you must add the
WASM_INSECURE_REGISTRIESenvironment variable to theistio-ingressgatewaydeployment, so that Istio can pull the image that the WASM plugin uses. To add the environment variable, run the following command:oc -n <istio-system> patch deployment istio-ingressgateway --type="json" --patch='[{"op":"add", "path": "/spec/template/spec/containers/0/env/-", "value": {"name": "WASM_INSECURE_REGISTRIES", "value": "customer-registry.com"}}]'oc -n <istio-system> patch deployment istio-ingressgateway --type="json" --patch='[{"op":"add", "path": "/spec/template/spec/containers/0/env/-", "value": {"name": "WASM_INSECURE_REGISTRIES", "value": "customer-registry.com"}}]' -
Add
istio-configureto theexclude_componentssection in yourinput.jsonfile. For details, refer to Configuring input.json. -
Verify that the configuration completed successfully by checking the pods in the
<istio-system>namespace:oc get pods -n <istio-system>oc get pods -n <istio-system>The WASM plugin pods should be in the
RunningorCompletedstate.
If you update the FQDN after installation, you must reconfigure Istio and the WASM plugin, unless the Automation Suite installer has administrative privileges. To reconfigure, you must take the following steps:
- Update the parameter values file mentioned in Step 3 with the new FQDN.
- Repeat all the steps for configuring Istio and installing the WASM plugin for routing.
Optional: installing istio-configure with a single script
Complete steps 1 and 2 first (create the image pull secret and the certificate Secret). Then, instead of running steps 3 and 4 individually, you can fill in the variables at the top of the following script and run it. The script generates the parameter values file and installs istio-configure directly from the OCI registry in one step. After it completes, continue from step 5.
#!/usr/bin/env bash
set -euo pipefail
# ---- Fill in these values ----
REGISTRY="registry.mycompany.com" # registry host, without protocol
ISTIO_CONFIGURE_VERSION="2.2510.0" # available: 2.2510.0, 2.2510.1, 2.2510.2, 2.2510.3 (match your Automation Suite version)
FQDN="autosuite.mycompany.com" # Automation Suite FQDN
PULL_SECRET="uipathpullsecret" # pull secret created earlier
UIPATH_NAMESPACE="uipath" # namespace where Automation Suite is deployed
ISTIO_NAMESPACE="istio-system" # namespace where Istio is installed
cat > istio-configure-values.yaml <<EOF
fqdn: ${FQDN}
gateway:
selector:
global:
imagePullSecret:
uipath:
registry: ${REGISTRY}
uipathServiceNamespace: ${UIPATH_NAMESPACE}
wasm:
image:
pullSecret: ${PULL_SECRET}
registry: oci://${REGISTRY}
EOF
"oci://${REGISTRY}/helm/istio-configure" --version "${ISTIO_CONFIGURE_VERSION}" \
--namespace "${ISTIO_NAMESPACE}" -f istio-configure-values.yaml
#!/usr/bin/env bash
set -euo pipefail
fqdn: ${FQDN}
gateway:
selector:
global:
imagePullSecret:
uipath:
wasm:
image:
EOF
To configure Istio for multiple Automation Suite installations in a single OpenShift cluster, you must add multiple custom-istio-configure which contains the FQDN and resources for different Automation Suite instances. You must fill in the helm values that correspond to your second or any subsequent installation.
You must to create different istio-configure values for each installation:
fqdn: <fqdn-for-second-installation> #the FQDN of the Automation Suite
gateway:
selector:
global:
imagePullSecret:
uipath:
uipathServiceNamespace: <second-installation-namespace> #namespace where the uipath application is deployed
wasm:
image:
gateway:
selector:
global:
imagePullSecret:
uipath:
wasm:
image:
You must change the name of custom-istio-configure to <namespace>-custom-istio-configure. This must be installed on the replicated namespace where second installation is performed.
helm upgrade --debug --install --wait <namespace>-custom-istio-configure \
- Step 1: Installing the service mesh
- Installing OpenShift Service Mesh 2.x
- Installing OpenShift Service Mesh 3.x
- Providing the Istio configuration
- Step 2: Configuring Istio and installing the WASM plugin for routing
- Overview
- Prerequisites
- Configuration and installation
- Optional: installing
istio-configurewith a single script - Step 3: Configuring Istio for multiple installations in a single cluster
