- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Configuring NLog
Add NLog extensions and configure advanced logging targets in Orchestrator on OpenShift.
Adding NLog extensions
Orchestrator loads the following extensions by default, so you do not need to include them in the folder or the NLog configuration:
NLog.Targets.ElasticSearchUiPath.Orchestrator.Logs.ElasticsearchMicrosoft.ApplicationInsights.NLogTargetNLog.Extensions.AzureEventHub
Only Linux-compatible extensions can be used in this setup, so make sure that your chosen NLog extension abides by this rule.
To make the extension available for use, it must be uploaded to the cluster storage. The uipathctl command line tool can do this via the uipathctl config orchestrator upload command:
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/extensions/directory
If you use an external storage configuration at the cluster level, you must indicate this by including the --is-external-storage parameter.
Advanced NLog configuration
Creating the advanced NLog configuration
Create the
nlog.config.jsonfile containing the standard sections: extensions, targets and rules.The extensions section is an array of items that specify the extension assemblies, via
assemblyFile, and the path of the assembly.If custom NLog plugins were loaded (as described in the Adding NLog extensions section), they will be referenced in the
extensionssection. -
Configure the target and rule in the
nlog.config.jsonfile. -
Apply the
nlog.config.jsonfile using theuipathctlcommand line tool:uipathctl config orchestrator update-config --nlog-config nlog.config.jsonuipathctl config orchestrator update-config --nlog-config nlog.config.jsonImportant:This action overwrites the existing custom NLog configuration. You can check what the existing configuration is by using this command:
uipathctl config orchestrator get-config --nlog-configuipathctl config orchestrator get-config --nlog-config
Example nlog.config.json file that writes logs to Azure Blob:
{ "NLog": {
"extensions": [
{ "assemblyFile": "NLog.Extensions.AzureBlobStorage.dll" }
"targets": {
"azureBlob": {
"type": "AzureBlobStorage",
"connectionString": "DefaultEndpointsProtocol=https;AccountName=test;AccountKey=key;EndpointSuffix=core.windows.net",
"container": "orchestratorlogs",
"blobName": "${date:format=yyyy-MM-dd hh.mm}",
"layout": {
"type": "JsonLayout",
"includeAllProperties": true,
"Attributes": [
{"name": "ts","layout": "${longdate}"},
{"name": "level","layout": "${level:upperCase=true}"},
{"name": "logger","layout": "${logger}"},
{"name": "message","layout": "${message}"},
{"name": "exception","layout": "${onexception:${ui-pretty-exception}}"}
"rules": { "70_Final": { "writeTo": "stdout,azureBlob" } }
{ "NLog": {
"extensions": [
"targets": {
"azureBlob": {
"layout": {
"Attributes": [
Example nlog.config.json file that writes robot logs to Splunk:
"Nlog": {
"extensions": [
{ "assemblyFile": "NLog.Targets.Splunk.dll" },
{ "assembly": "UiPath.Orchestrator.Logs.DatabaseBulk.NLogTarget" }
"targets": {
"Splunk": {
"type": "AsyncWrapper",
"overflowAction": "Discard",
"queueLimit": 10000,
"batchSize": 200,
"timeToSleepBetweenBatches": 1,
"target": {
"type": "SplunkHttpEventCollector",
"serverUrl": "http://splunk.example.com",
"token": "splunk-token",
"channel": "",
"source": "${logger}",
"sourceType": "_json",
"index": "uipath",
"retriesOnError": "0",
"batchSizeBytes": "0",
"batchSizeCount": "0",
"includeEventProperties": "true",
"includePositionalParameters": "true",
"includeMdlc": "true",
"maxConnectionsPerServer": "10",
"ignoreSslErrors": "false",
"useProxy": "false",
"proxyUrl": "",
"proxyPassword": ""
"rules": {
"20_Robot_Primary": { "writeTo": "Splunk,database,insightsRobotLogs" }
"Nlog": {
"extensions": [
"targets": {
"Splunk": {
"batchSize": 200,
"target": {
"channel": "",
"index": "uipath",
"proxyUrl": "",
"proxyPassword": ""
"rules": {
Sizing the Splunk queueLimit
The queue absorbs Splunk backlog during slowdowns. Size it to your peak throughput, not your average:
queueLimit = peak_logs_per_sec × acceptable_backlog_seconds
| Deployment | Peak rate | Backlog tolerance | queueLimit |
| Small | ~10 logs/sec | 60 s | 600 |
| Medium | ~35 logs/sec | 300 s | 10000 |
| Large | ~200 logs/sec | 60 s | 12000 |
Best practices for Splunk targets
- Use
overflowAction: Discardfor secondary targets. External log targets such as Splunk are typically analytics or observability destinations, the Orchestrator database is the source of truth. If the external target cannot keep up, dropping its copy is preferable to blocking application threads. - Reserve
overflowAction: Blockfor targets where loss is not acceptable.Blockprevents event loss but does not prevent blocking. When the queue fills under sustained load it reverts to the same thread-blocking behavior asBufferingWrapper. Only use it when the external target is a compliance or audit requirement, and sizequeueLimitgenerously to match peak throughput. - Always keep
databasein thewriteTorule alongside any external target. This ensures no robot log is permanently lost regardless of the availability or performance of the external target. - Flush before shutdown.
AsyncWrapperholds events in an in-memory queue. Ensure NLog targets are flushed on graceful shutdown to avoid losing the tail of the queue when the process exits.
Updating the advanced NLog configuration
The uipathctl commands needed for updating the NLog configuration are:
uipathctl config orchestrator get-config --nlog-config- Exports the current configuration in a key-value pair json file, ready for editing.uipathctl config orchestrator update-config --nlog-config nlog.config.json- Updates the configuration with your changes.
- Export the current custom NLog configuration to a json file using this command:
uipathctl config orchestrator get-config --nlog-config > nlog.config.jsonuipathctl config orchestrator get-config --nlog-config > nlog.config.json - Edit the exported
nlog.config.jsonfile as needed. You can add, remove, or change any of its settings.Note:You must export the file again every time you need to make a change, since the update overwrites all NLog settings.
- Update the NLog configuration using this command:
uipathctl config orchestrator update-config --nlog-config nlog.config.json orchestrator config updateduipathctl config orchestrator update-config --nlog-config nlog.config.json orchestrator config updated
