Validating and configuring infrastructure with uipathctl
Use uipathctl to generate the required databases and storage buckets and to validate infrastructure prerequisites before installing Automation Suite on OpenShift.
Before you install Automation Suite, use uipathctl to provision the required infrastructure and to confirm that your environment meets the prerequisites. Complete the following steps, both run with uipathctl:
  1. Setting up the required resources - use uipathctl prereq create to set up the SQL databases, object storage buckets, and other components required for the installation.
  2. Prerequisite checks - use uipathctl prereq run to validate that the required cloud infrastructure is provisioned correctly and that input.json is valid, before starting the installation.
For an example of what the checks return, refer to Output example: prerequisite check.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
