- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Automation Suite stack
Automation Suite architecture layers including UiPath managed services and customer-managed infrastructure components.
High-level architecture
Automation Suite allows you to bring and manage your own Kubernetes cluster.
The following diagram shows the Automation Suite architecture with all component layers.
There are two sections of the stack:
- UiPath® managed: UiPath® services and components optimized for Automation Suite provided and supported by UiPath®.
- Customer managed: Prerequisites for deploying Automation Suite on your cloud infrastructure managed and supported by you. For supported configurations, refer to the Compatibility matrix.
| Stack Component | Description |
| UiPath® managed | |
| UiPath® products | When you deploy Automation Suite, a minimum set of shared capabilities are installed by default, such as UiPath® Portal, Identity, License, Org Management, and Audit. You can choose which UiPath® products to enable on Automation Suite both at the time of installation or post-installation. Note that some products have product-specific prerequisites you must address. |
| Optional to install | |
| External Secrets Operator | External Secrets Operator (ESO) is a Kubernetes operator designed to synchronize secrets from external secret management services, such as AWS Secrets Manager, HashiCorp Vault, Google Secrets Manager, Azure Key Vault, and other, directly into Kubernetes as native Secret objects. You can choose to install your own version of the External Secrets Operator if you prefer not to install the Automation Suite-bundled External Secrets Operator. |
| Customer managed | |
| Kubernetes cluster (OpenShift) | OpenShift is a managed Kubernetes service from Red Hat. Make sure to configure your OpenShift cluster correctly, with the required worker nodes and capacity. |
| ArgoCD | Open-source declarative CD tool for Kubernetes. It follows the GitOps pattern of using Git repositories as the source of truth for defining the desired application state. It is optimized to provide application life cycle management (ALM) capabilities for Automation Suite. OpenShift provides the OpenShift GitOps Operator, which ensures similar functionality to ArgoCD. |
| Istio | Open-source service mesh that provides functionality such as ingress, request routing, and traffic monitoring, for the microservices running inside the Kubernetes cluster. OpenShift provides OpenShift Service Mesh, which ensures similar functionality to Istio. |
| Object storage | Automation Suite and UiPath® Services require Object Storage - Azure Blob Storage, Amazon S3 (Simple Storage Service), or an S3-compatible objectstore. Red Hat provides OpenShift Data Foundation as an S3-compatible object storage solution. |
| Block storage | Block storage is similar to disk storage needed for Automation Suite platform and UiPath® products. Automation Suite is compatible with Azure Disk Storage and Amazon’s Elastic Block Storage. Also, Red Hat provides OpenShift Data Foundation as a block storage solution. |
| File Storage | File storage is hierarchical data storage methodology and is needed for several UiPath® products. Automation Suite is compatible with Azure Files and Elastic File Storage from Microsoft and AWS, respectively. |
| Caching | Caching is required by several UiPath® products. Automation Suite is compatible with Cloud Redis for Azure and Elasticache for AWS. You can also use the Redis Enterprise Operator from OpenShift. |
| Database | SQL Server and SQL databases are needed for all UiPath® products. Automation Suite is compatible with Microsoft SQL server, Azure SQL and AWS managed (RDS) SQL services. AutomationSuite_Airflow for Process Mining; AutomationSuite_Taas and AutomationSuite_Taas_Visibility for TaaS; and AutomationSuite_A4D for A4D). |
| Cert Manager | Cert Manager is an open-source certificate controller for Kubernetes. You can choose to keep the Cert Manager pre-configured within Automation Suite or bring your own. If you bring your own, you are responsible for managing the lifecycle of that component. |
| Secretstore | Secretstore in Automation Suite is an external source for storing sensitive credentials used as a part of automation suite. It can be a Kubernetes secret or an key vault. |
Istio and ArgoCD are mandatory components that Automation Suite is dependent on. For Automation Suite on OpenShift installations, OpenShift Service Mesh can replace Istio and the OpenShift GitOps Operator can replace ArgoCD. As installing Istio, ArgoCD or the equivalent components from OpenShift requires admin privileges, you must install the components separately before installing Automation Suite.
Responsibility matrix
| Activity | UiPath® responsibility | Customer responsibility |
| Infrastructure prerequisites |
| Network policies (optionally provided by UiPath®) | N/A | N/A |
| Gatekeeper and OPA policies (optionally provided by UiPath®) | N/A | N/A |
| Automation Suite upgrades |
| Infrastructure upgrades |
| Backup and Restore | N/A |
| Support |
