- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Automation Suite products
UiPath products included in Automation Suite with their dependencies and features on OpenShift.
Automation Suite lets you manage your self-hosted UiPath® platform as one product. However, not all of our self-hosted products are part of Automation Suite.
The following products are part of the Automation Suite bundle. You have the ability to enable or disable products at any time after their installation.
- Action Center (Actions and Processes)
- Agents
- AI Center (AI Center connected to an external Orchestrator not supported)
- AI Trust Layer
- LLM Gateway
- LLM Observability
- Context Grounding (also referred to Enterprise Context Service, or ECS)
- Apps
- Automation Hub
- Automation Ops
- Autopilot for Everyone
- Autopilot for developers
- Autopilot for testers
- Data Service
- Document Understanding
- Healing Agent
- Semantic Proxy
- Insights
- Integration Service
- Maestro
- Temporal as a Service (TaaS) - automatically enabled when Maestro is installed; no additional licensing required
- Orchestrator
- Process Mining
- ScreenPlay
- Semantic Proxy
- Solutions
- Studio Web
- Test Manager
Some Automation Suite products have additional dependencies on each other, as listed in the following table:
| Product | Dependency |
| Agents |
| AI Computer Vision |
| Apps |
| Automation Hub |
As Task Mining is not available in Automation Suite, the Automation Hub integration with Task Mining is also not available. |
| Automation Suite Robots |
| Autopilot for developers |
| Autopilot for Everyone |
| Autopilot for Testers |
| Context Grounding (ECS) |
| Document Understanding |
| Healing Agent |
| Integration Service |
| LLM Gateway |
| LLM Observability |
| Maestro |
| Process Mining |
| ScreenPlay |
| Solutions |
| Studio Web |
