- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- How to uninstall Automation Suite
- How to resolve prereq connectivity check failure on OpenShift 4.16–4.18
- How to deploy Insights in a FIPS-enabled cluster
- How to disable CDI auto-enabling in Nvidia GPU Operator
- How to URL-encode a PostgreSQL connection string password
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
How to resolve prereq connectivity check failure on OpenShift 4.16-4.18
Resolve prerequisite connectivity check failures on OpenShift 4.16-4.18 control-plane nodes.
When running Automation Suite prerequisites (uipathctl prereq run) on an OpenShift cluster (versions 4.16-4.18), the cluster connectivity check can fail on certain nodes with the following error:
time="2025-07-22T13:51:02Z" level=info msg="Wizard is running on :8080"
Error: listen failed with error: listen tcp :8080: bind: address already in use
The error typically occurs only on control-plane nodes.
To address this issue, you can use one of the following workaround options:
Run prereqs on worker nodes only.
To avoid scheduling prereq pods on control-plane nodes, you must apply node labels to target worker nodes only. You must update
input.jsonto include thenode_labelssection, as shown in the following example:"node_labels": { "node-role.kubernetes.io/worker": "" }"node_labels": { "node-role.kubernetes.io/worker": "" }This ensures that all prerequisite checks, including connectivity, are executed only on worker nodes and not on control-plane nodes where the conflict occurs.
Skip the connectivity check. If targeting specific node roles is not possible (when nodes are configured with multiple roles), you must run the prereq command excluding the connectivity check:
uipathctl prereq run --excluded CONNECTIVITYuipathctl prereq run --excluded CONNECTIVITY
