Skipping host library installation
Skip host library installation when managing components externally in Automation Suite.
Overview​
During installation, Automation Suite installs the latest libraries into the host libraries feed.
In specific troubleshooting or compatibility scenarios, you may want to skip installing these libraries during installation.
You can do this by using the advanced configuration mechanism.
Warning:
This configuration should only be used after consulting UiPath Support.
Skipping the installation of libraries may cause existing products or features to malfunction.
Configuration​
To skip installing libraries, add the following configuration under the Orchestrator section in the input.json file.
  "orchestrator": {
    "advanced_configuration": {
      "libraries": {
        "enabled": false
  "orchestrator": {
      "libraries": {
        "enabled": false
When this configuration is applied:
  • The installer does not install the latest libraries into the host libraries feed.
  • Existing libraries already present in the feed remain unchanged.
Important notes​
  • The values.yaml file cannot be modified at install time.
  • All overrides must be defined in input.json.
  • Only specify parameters that require overriding.
  • Any changes made only in ArgoCD may be overwritten if the installer is run again.
  • Overview​
  • Configuration​
  • Important notes​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
