Disaster recovery - Active/Passive
Disaster recovery concepts and implementation for Automation Suite multi-site deployments.
This article walks you through the core concepts and architecture of Automation Suite disaster recovery, covering Active/Passive deployments.
Ensuring continuous business automation is at the core of any automation platform. Automation Suite can withstand the complete failure of nodes, entire data centers, or regions. You can deploy Automation Suite as an Active/Passive configuration.
Automation Suite multi-site deployments in Active/Passive mode support the following scenarios:
  • Same-region deployment - Two Automation Suite clusters deployed in the same region;
  • Cross-region deployment - Two Automation Suite clusters deployed in different regions.
The following table provides details on which Automation Suite products you can deploy in Active/Passive mode.
ProductSupport for Active/Passive
Orchestrator✅
Action Center✅
Agents❌
AI Center✅
Apps✅
Automation Ops✅
Automation Suite Robots✅
Computer Vision✅
Data Service✅
Document Understanding✅
Test Manager✅
Automation Hub❌
Insights❌
Healing Agent❌
Process Mining❌
Integration Service✅
LLM gateway❌
LLM observability❌
ECS❌
ScreenPlay❌
Semantic Proxy❌
Studio Web❌
Autopilot for Everyone❌
Maestro❌
Temporal as a Service (TaaS)❌
Autopilot for developers✅
Solutions✅
Note:
  • You can install products that are not supported in Disaster Recovery with Active/Passive . However, you cannot use these products when the primary cluster is down.
  • For AI Center, the training pipeline functionality is available only in the primary cluster.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
