- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Advanced configuration options for Orchestrator in Automation Suite on OpenShift.
Advanced configuration allows support engineers to override specific service configuration parameters used during Automation Suite installation and deployment.
Using advanced configuration, you can:
- Override resource requests and limits for deployments, stateful sets, and daemon sets.
- Modify Horizontal Pod Autoscaler (HPA) settings.
- Override specific Helm chart parameters used by services during installation.
All advanced configuration changes must be defined in the input.json file to ensure configuration consistency across environments.
Any configuration changes performed directly in ArgoCD must also be replicated in input.json.
If the installer is re-run, changes made only in ArgoCD may be overwritten.
Identify the parameters you want to override.
You can locate these parameters in one of the following places:
- The
values.yamlfile in the service Helm chart within the service-fabric-packaging repository. - The Parameters section of the corresponding application in ArgoCD.
Example
If the following parameter appears in the ArgoCD Parameters section:
requests.cpu=10requests.cpu=10This corresponds to the following JSON configuration:
"requests": { "cpu": "10" }"requests": { "cpu": "10" } - The
Modify the
input.jsonfile.Add an
advanced_configurationsection under the corresponding service ininput.json. Convert the parameter format from YAML to JSON before adding it to the file.The following example overrides resource parameters for the Orchestrator service:
{ "orchestrator": { "advanced_configuration": { "requests": { "cpu": "100m", "memory": "100Mi", "storage": "1Gi", "gpu": 1 }, "limits": { "cpu": "200m", "memory": "200Mi", "storage": "2Gi", "gpu": 1 } } } }{ "orchestrator": { "advanced_configuration": { "requests": { "cpu": "100m", "memory": "100Mi", "storage": "1Gi", "gpu": 1 }, "limits": { "cpu": "200m", "memory": "200Mi", "storage": "2Gi", "gpu": 1 } } } } -
Update autoscaling parameters (optional).
You can also override Horizontal Pod Autoscaler (HPA) parameters using the
autoscalingconfiguration block.{ "orchestrator": { "advanced_configuration": { "autoscaling": { "minReplicas": 1, "maxReplicas": 3, "targetCPUUtilizationPercentage": 70, "targetMemoryUtilizationPercentage": 70, "scaleUpStabilizationWindowSeconds": 60, "scaleUp": { "policy": { "type": "Pods", "value": 1, "periodSeconds": 60 } }, "scaleDownStabilizationWindowSeconds": 60, "scaleDown": { "policy": { "type": "Pods", "value": 1, "periodSeconds": 60 } } } } } }{ "orchestrator": { "advanced_configuration": { "autoscaling": { "minReplicas": 1, "maxReplicas": 3, "targetCPUUtilizationPercentage": 70, "targetMemoryUtilizationPercentage": 70, "scaleUpStabilizationWindowSeconds": 60, "scaleUp": { "policy": { "type": "Pods", "value": 1, "periodSeconds": 60 } }, "scaleDownStabilizationWindowSeconds": 60, "scaleDown": { "policy": { "type": "Pods", "value": 1, "periodSeconds": 60 } } } } } } -
Validate the changes.
Before applying the configuration through the installer, you can optionally validate the parameters. To do this:
- Modify the parameters directly in the ArgoCD application under the Parameters section.
- Confirm the configuration behaves as expected.
- Copy the validated configuration into the
input.jsonfile.
