- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Durable Execution Service troubleshooting
Installing Automation Suite
Install Automation Suite on OpenShift cluster using uipathctl commands and input.json configuration.
Installation overview
This page walks you through the high-level installation instructions for Automation Suite.
Before you begin, consider the following:
- To deploy and manage Automation Suite, you must have knowledge of Kubernetes and cloud resource management. If you encounter issues installing and configuring Automation Suite, contact UiPath® Professional Services.
- The installation process generates self-signed certificates on your behalf if you grant the installer admin privileges. You should replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. For instructions, refer to Managing the certificates.
- Automation Suite supports enabling Federal Information Processing Standard 140-2 (FIPS 140-2). For details, refer to Security and compliance.
Running the installation
To check which deployment scenarios are available for Automation Suite, refer to Deployment scenarios.
To install Automation Suite, take the following steps:
After successfully validating the prerequisites, you install Automation Suite by running the following command:
uipathctl manifest apply input.json --versions versions.jsonuipathctl manifest apply input.json --versions versions.jsonFor an output example, refer to Output example: Automation Suite installation.
Note:If you encounter issues while running the installation, rerun the installation commands with all the arguments and flags, and add
--log-level debugfor more detailed output. -
Validate that your installation is successful and services are healthy by running the following command:
uipathctl health check --namespace <uipath> --versions versions.jsonuipathctl health check --namespace <uipath> --versions versions.json
