- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
input.json example
Complete input.json configuration example for Automation Suite installation on OpenShift.
The following an example shows an input.json file with all the products enabled, as well as the mandatory and optional configuration parameters for Automation Suite. You can use the example as reference and make changes according to your environment requirements.
Note that the minimum UiPath® product selection requires the platform services to be enabled. Make sure to replace FQDNs, hostnames, usernames and passwords, and SQL connection strings with your own configurations.
"fqdn": "automationsuite.mycompany.com",
"admin_username": "admin",
"admin_password": "<your-password>",
"registries": {
"docker": {
"url": "registry.mycompany.com",
"username": "registryuser",
"password": "<your-password>",
"pull_secret_value": "<your-pull-secret>"
"helm": {
"sql_connection_string_template": "Server=tcp:sql.mycompany.com,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sql.mycompany.com;Password='<your-password>';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"sql_connection_string_template_odbc": "SERVER=sql.mycompany.com;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD={<your-password>};Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;hostNameInCertificate=sql.mycompany.com",
"sql_connection_string_template_jdbc": "jdbc:sqlserver://sql.mycompany.com;database=DB_NAME_PLACEHOLDER;user=testadmin@sql.mycompany.com;password={<your-password>};encrypt=true;trustServerCertificate=false;hostNameInCertificate=*.database.windows.net;loginTimeout=30;",
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://testadmin%40sql.mycompany.com:<your-password>@sql.mycompany.com:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=no&Encrypt=yes",
"postgresql_connection_string_template_sqlalchemy_pyodbc": "postgresql+psycopg2://sa:<your-password>@135.235.240.165:5432/DB_NAME_PLACEHOLDER",
"postgresql_connection_string_template_sqlalchemy_asyncpg": "postgresql+asyncpg://sa:<password>@135.235.240.165:5432/DB_NAME_PLACEHOLDER",
"orchestrator": {
"enabled": true
"profile": "default",
"network": {
"ipv4": { "enabled": true },
"ipv6": { "enabled": true }
"kubernetes_distribution": "openshift",
"ingress": {
"gateway_selector": {
"istio": "ingressgateway"
"ingress_gateway_secret": "istio-ingressgateway-certs",
"namespace": "<istio-system>",
"istio_gateway_service_name": "istio-ingressgateway"
"istioMinProtocolVersion": "TLSV1_3",
"argocd": {
"application_namespace": "uipath",
"project": "uipath"
"storage_class": "managed-premium",
"storage_class_single_replica": "managed-premium",
"storage_class_name_with_rwx_support": "managed-premium",
"exclude_components": [
"argocd",
"monitoring",
"istio",
"istio-configure",
"logging",
"gatekeeper",
"network-policies",
"velero",
"alerts",
"cert-manager",
"external-secrets"
"sql": {
"server_url": "sql.mycompany.com",
"port": "1433",
"username": "testadmin",
"create_db": true
"namespace": "uipath",
"fabric": {
"redis": {
"hostname": "redis.mycompany.com",
"port": 6380,
"tls": true
"external_object_storage": {
"enabled": true,
"storage_type": "s3",
"fqdn": "s3storage.mycompany.com",
"port": 443,
"region": "us-east-2",
"access_key": "<your-access-key>",
"secret_key": "<your-secret-key>"
"telemetry_optout": true,
"platform": {
"enabled": true
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"action_center": {
"enabled": true
"apps": {
"enabled": true
"test_manager": {
"enabled": true
"dataservice": {
"enabled": true
"aicenter": {
"enabled": true
"documentunderstanding": {
"enabled": true
"processmining": {
"enabled": true
"semanticproxy": {
"enabled": true
"insights": {
"enabled": true
"ecs": {
"enabled": true
"llmgateway": {
"enabled": true,
"llmobservability": {
"enabled": true,
"automationsolutions": {
"enabled": true,
"autopiloteveryone": {
"enabled": true,
"maestro": {
"enabled": true,
"taas": {
"enabled": true
"a4d": {
"enabled": true,
"registries": {
"docker": {
"helm": {
"orchestrator": {
"enabled": true
"network": {
"ingress": {
"argocd": {
"project": "uipath"
"argocd",
"monitoring",
"istio",
"istio-configure",
"logging",
"gatekeeper",
"network-policies",
"velero",
"alerts",
"cert-manager",
"external-secrets"
"sql": {
"port": "1433",
"create_db": true
"fabric": {
"redis": {
"port": 6380,
"tls": true
"enabled": true,
"port": 443,
"platform": {
"enabled": true
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"action_center": {
"enabled": true
"apps": {
"enabled": true
"test_manager": {
"enabled": true
"dataservice": {
"enabled": true
"aicenter": {
"enabled": true
"enabled": true
"processmining": {
"enabled": true
"semanticproxy": {
"enabled": true
"insights": {
"enabled": true
"ecs": {
"enabled": true
"llmgateway": {
"enabled": true,
"enabled": true,
"enabled": true,
"enabled": true,
"maestro": {
"enabled": true,
"taas": {
"enabled": true
"a4d": {
"enabled": true,
