Kubernetes cluster and nodes
Kubernetes cluster and node requirements for Automation Suite on OpenShift.
Cluster and permissions​
You can bring your own Kubernetes cluster and follow your standard practices to provision and manage it.
An admin user must install specific required components separately, before the Automation Suite platform installation. After installing the required components, you can execute the installer. For the list of required permissions, refer to Granting installation permissions.
Node capacity​
To estimate node capacity based on your product and scale requirements, use the UiPath Automation Suite Install Sizing Calculator.
The root volume requirement for agent (worker) nodes is 256 GB.
At a minimum, to start with the mandatory platform services (Identity, licensing, and routing) and Orchestrator, you must provision 8 vCPU and 16 GB RAM per node.
Note:
We do not recommend using spot instances in Automation Suite in production scenarios, due to stability and performance issues.
Autoscaling​
We recommend enabling autoscaling on your cluster to ensure high reliability and to avoid business interruptions.
Additional Automation Suite Robots requirements​
Automation Suite Robots require additional worker node(s).
The hardware requirements for the Automation Suite Robots node depend on the way you plan to use your resources. In addition to the additional agent node requirements, you also need a minimum of 10 GB of file storage to enable package caching.
For details, refer to Storage documentation.
The following sections describe the factors that impact the amount of hardware the Automation Suite Robots node requires.
Robot size​
The following table describes the required CPU, RAM, and storage for all robot sizes.
SizeCPURAMStorage
Small0.51 GB1 GB
Standard12 GB2 GB
Medium24 GB4 GB
Large610 GB10 GB
Agent node size​
The resources of the Automation Suite Robots agent node have an impact on the number of jobs that can be run concurrently. The reason is that the number of CPU cores and the amount of RAM capacity are divided by the CPU/RAM requirements of the job.
For example, a node with 16 CPUs and 32 GB of RAM would be able to run any of the following:
  • 32 Small jobs
  • 16 Standard jobs
  • 8 Medium jobs
  • 2 Large jobs
Job sizes can be mixed, so at any given moment, the same node could run a combination of jobs, such as the following:
  • 10 Small jobs (consuming 5 CPUs and 10 GB of RAM)
  • 4 Standard jobs (consuming 4 CPUs and 8 GB of RAM)
  • 3 Medium jobs (consuming 6 CPUs and 12 GB of RAM)
Kubernetes resource consumption​
Given that the node is part of a Kubernetes cluster, the Kubernetes agent present on the server (kubelet) consumes a small amount of resources. Based on our measurements, the kubelet consumes the following resources:
  • 0.6 CPU
  • 0.4 GB RAM
A node similar to the one previously described would actually have approximately 15.4 CPUs and 31.6 GB of RAM.
Automatic machine size selection​
All your cross-platform processes have the Automation Suite Robots option set to Automatic by default. This setting selects the appropriate machine size for running the process using serverless robots.
When automatically choosing the size, the criteria listed in the following table are evaluated in order. As soon as one criterion is satisfied, the corresponding machine size is chosen and the remaining criteria are not evaluated.
OrderCriterionMachine size
1Remote debugging jobMedium
2Process depends on UI Automation OR Process depends on the UiPath Document Understanding activitiesStandard
3Other unattended processSmall
Additional Document Understanding recommendations​
For increased performance, you can install Document Understanding on an additional agent node with GPU support. Note, however, that AI Center-based projects in Document Understanding are fully functional without the GPU node. Actually, Document Understanding uses CPU VMs for all its extraction and classification tasks, while for OCR we strongly recommend the usage of a GPU VM.
For details about the CPU/GPU usage within the Document Understanding framework, refer to CPU and GPU Usage.
If you want to use an additional node with GPU support, you must meet the following requirements:
HardwareMinimum requirement
Processor8 (v-)CPU/cores
RAM52 GB
OS disk256 GB SSD Min IOPS: 1100
Data diskN/A
GPU RAM11 GB
When adding the GPU node pool, taint the nodes with --node-taints nvidia.com/gpu=present:NoSchedule. Automation Suite GPU workloads are configured to tolerate the nvidia.com/gpu taint key only, so you must use this exact key. If you taint the nodes with a different key, the scheduler cannot place the GPU pods on the node and they remain unscheduled.
To ensure proper scheduling of GPU workloads, make sure your DaemonSet (NFD or Nvidia GPU Operator) YAML configuration includes a matching tolerations block.
You can use the following example:
tolerations:
- key: "nvidia.com/gpu"
operator: "Equal"
value: "present"
effect: "NoSchedule"
tolerations:
operator: "Equal"
value: "present"
Automation Suite supports NVIDIA GPUs. To learn about how to configure NVIDIA GPUs (such as drivers), refer to the OpenShift documentation.
Additional Document Understanding modern projects requirements​
With CPU inference activated, a minimum of 2 GPUs is required.
To enable CPU inference, set the enable_cpu_inference property to true, as indicated in the Enabling or disabling Document Understanding section.
Note:
Inference may be up to 10 times slower. We recommend using it for documents with a maximum of 125 pages, as inference might fail for larger documents.
Without CPU inference, a minimum of 5 GPUs is required for Document Understanding modern projects. The example scenario in the following table demonstrates how 5 GPUs is enough to process 300 pages.
Note:
For Document Understanding modern projects, the minimum recommended GPU is NVIDIA T4.
FunctionNumber
Custom model pages processed per hour300
Out of the box model pages processed per hour0
Models training in parallel1
Number of pages in all projects - Design time200
Number of document types per project version3
The 5 GPUs are distributed amongst different functions, as detailed in the following table:
ServiceNumber of GPUs
OCR replicas1
Custom model training replicas1
Custom model replicas2
Out of the box model replicas1
Total5
In addition to the GPU demands, Document Understanding modern projects also require specific CPU resources for optimal performance. For optimal performance, a minimum of 18 vCPUs is required.
With the modern Document Understanding project, an additional 4 TB of the objectstore is required to perform the activities from the provided examples continuously for one year. You can start with a smaller number, but the activity will fail once the storage is complete, unless you explicitly scale it.
If you are provisioning for one year of continuous processing, you will need 4 TB for Document Understanding modern projects and 512 GB for the other products. The total will be 4.5 TB of storage. Similarly, if you start with six months of processing, you will need 2 TB for Document Understanding modern projects and 512 GB for the other products. In this case the total will be 2.5 TB.
Note:
For more detailed calculations and the capacity required for your needs, refer to the UiPath Automation Suite Install Sizing Calculator.
Provisioning MIG-enabled GPUs​
Automation Suite Document Understanding workloads support running on Virtual GPUs (VGPUs) created with NVIDIA MIG (Multi-Instance GPU) technology.
To run Document Understanding in these conditions, keep in mind the following requirements:
  • GPU memory (VRAM): at least 16 GB per VGPU. UiPath only supports the single strategy, meaning that all VGPUs will be exactly the same.
  • Storage: at least 80 GB per VGPU
Enabling MIG-enabled GPUs in Kubernetes​
After provisioning the MIG enabled GPUs in your cluster with profiles matching or exceeding the above minimum requirements, ensure that the GPUs are schedulable Kubernetes. The node must report a non-zero number of GPUs before workloads can be scheduled on it.
To make the GPUs schedulable, you have two options:
  • Option A: Follow the official GPU setup documentation of your cloud provider, or the one on the NVIDIA website:
  • Option B (Alternative): Deploy the NVIDIA device plugin directly:
    1. Create a new namespace:
      kubectl create namespace gpu-resources
    2. Apply the following configuration, replacing migEnabledPoolName with the label that matches your GPU node:
      apiVersion: v1
      kind: Pod
      metadata:
        namespace: gpu-resources
      spec:
       affinity:
          nodeAffinity:
            requiredDuringSchedulingIgnoredDuringExecution:
              nodeSelectorTerms:
              - matchExpressions:
                - key: agentpool
                  operator: In
                  values:
                  # To be changed to a selector that matches the GPU nodes
                  - migEnabledPoolName
       containers:
       - args:
         - --fail-on-init-error=false
         env:
         - name: MPS_ROOT
           value: /run/nvidia/mps
         - name: MIG_STRATEGY
            # We only support the single strategy for now
           value: single
         - name: NVIDIA_MIG_MONITOR_DEVICES
           value: all
         - name: NVIDIA_VISIBLE_DEVICES
           value: all
         - name: NVIDIA_DRIVER_CAPABILITIES
           value: compute,utility
         image: nvcr.io/nvidia/k8s-device-plugin:v0.17.3
         imagePullPolicy: IfNotPresent
         securityContext:
           allowPrivilegeEscalation: true
           capabilities:
             add:
             - SYS_ADMIN
         terminationMessagePath: /dev/termination-log
         terminationMessagePolicy: File
         volumeMounts:
         - mountPath: /var/lib/kubelet/device-plugins
       tolerations:
       - key: CriticalAddonsOnly
         operator: Exists
       - effect: NoSchedule
         key: nvidia.com/gpu
         operator: Exists
       terminationGracePeriodSeconds: 30
       volumes:
       - hostPath:
           path: /var/lib/kubelet/device-plugins
           type: ""
      apiVersion: v1
      kind: Pod
      metadata:
      spec:
       affinity:
          nodeAffinity:
              nodeSelectorTerms:
              - matchExpressions:
                - key: agentpool
                  operator: In
                  values:
       containers:
       - args:
         env:
         - name: MPS_ROOT
           value: single
           value: all
           value: all
         securityContext:
           capabilities:
             add:
             - SYS_ADMIN
         volumeMounts:
       tolerations:
         operator: Exists
         key: nvidia.com/gpu
         operator: Exists
       volumes:
       - hostPath:
           type: ""
After deploying the plugin, the node's Allocatable section should show the correct number of VGPUs under nvidia.com/gpu, based on the MIG profile you configured. The node should now be schedulable and ready to run Document Understanding workloads.
Additional Temporal as a Service (TaaS) requirements​
When Maestro is enabled, TaaS runs as a set of Kubernetes deployments within the cluster. In the default profile, TaaS requires a minimum of 5.5 vCores and 5.5 GB RAM of available cluster headroom.
Deployments​
TaaS consists of the following Kubernetes deployments, each responsible for a distinct function within the Temporal service:
DeploymentDescription
taas-temporal-frontendEntry point for all client connections to the Temporal service
taas-temporal-internalFrontendHandles internal inter-service communication within the cluster
taas-temporal-historyManages workflow execution history and state transitions
taas-temporal-matchingMatches scheduled tasks to available workers for execution
taas-temporal-workerProcesses internal Temporal system workflows
taas-temporal-webWeb UI for visualizing and monitoring workflows
taas-temporal-admintoolsUtility deployment for issuing Temporal admin commands within the cluster
Pod resource requirements​
The following table lists the CPU and memory requests and limits for each TaaS deployment. Resource settings are the same across all TaaS profiles.
DeploymentCPU requestCPU limitMemory requestMemory limit
taas-temporal-frontend250m1256Mi256Mi
taas-temporal-internalFrontend250m1256Mi256Mi
taas-temporal-history250m14Gi4Gi
taas-temporal-matching250m1512Mi512Mi
taas-temporal-worker100m1256Mi256Mi
taas-temporal-web100m200m128Mi128Mi
taas-temporal-admintools100m200m128Mi128Mi
Autoscaling​
TaaS uses Horizontal Pod Autoscaler (HPA) for select deployments. The scaling behavior depends on the TaaS profile, as described in the following table.
DefaultLiteHA
Autoscaling enabledNoYesYes
HPAs created044
taas-temporal-frontend replicas1 (static)1–3 (CPU 80%)2–3 (CPU 80%)
taas-temporal-internalFrontend replicas1 (static)1–3 (CPU 80%)2–3 (CPU 80%)
taas-temporal-history replicas1 (static)1–5 (CPU 80% + Mem 70%)2–5 (CPU 80% + Mem 70%)
taas-temporal-matching replicas1 (static)1–3 (CPU 80%)2–3 (CPU 80%)
taas-temporal-worker replicas1 (static)1 (static)2 (static)
taas-temporal-web replicas1 (static)1 (static)1 (static)
taas-temporal-admintools replicas1 (static)1 (static)1 (static)
PDBsdisabledenabledenabled
numHistoryShards64128256
Node scheduling​
Node taints and labels are required for Automation Suite Robots. For Document Understanding, they are recommended.
AI Center and DU example:
  • For CPU:
    oc taint node <node_name> aic.ml/cpu=present:NoSchedule
  • For GPU:
    oc taint node <node_name> nvidia.com/gpu=present:NoSchedule
Automation Suite Robots example:
You must configure a dedicated worker node with the correct taint and labels for Automation Suite Robots. Without these, asrobots pods fail to schedule regardless of available resources on other nodes.
Run both of the following commands - the taint alone is not sufficient:
oc taint node <node_name> serverless.robot=present:NoSchedule
oc label node <node_name> serverless.robot=true serverless.daemon=true
Important:
If you have custom node taints that are enforced by Gatekeeper Policy, such as specific roles for worker nodes or labels, they will not be passed to Automation Suite and may interrupt the installation process.
To learn about taints and tolerations, refer to Kubernetes documentation.
Additional self-hosted model requirements​
Self-hosted models require GPU hardware. Minimum requirements depend on model size:
Model sizeMinimum GPU configuration
7B parameters1 × 80 GB GPU
70B parameters4 × 80 GB GPU
120B+ parameters8 × 80 GB GPU
For details, refer to Self-hosted models.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
