How to deploy Insights in a FIPS-enabled cluster
Deploy Insights on dedicated non-FIPS node in FIPS-enabled OpenShift cluster.
Insights does not currently support FIPS. However, you can deploy Insights in a FIPS-enabled cluster by running it on a dedicated non-FIPS node using node selectors and tolerations.
Take the following steps:
  1. Add a non-FIPS node to your FIPS-enabled cluster.
  2. Apply a taint to the non-FIPS node to prevent other workloads from scheduling on it, and assign it a label that matches the node selector you will configure in the next step.
  3. In the input.json file, configure Insights to run exclusively on the non-FIPS node using node selectors and tolerations:
      "insights": {
        "enabled": true,
        "advanced_configuration": {
          "global": {
            "nodeSelectorLabels": {
              "nodename": "insights"
            "tolerations": [
                "key": "insights",
                "operator": "Equal",
                "value": "true",
                "effect": "NoSchedule"
      "insights": {
        "enabled": true,
          "global": {
            "tolerations": [
                "key": "insights",
                "value": "true",
    Note:
    Make sure the nodeSelectorLabels and tolerations match the labels and taints you applied to your non-FIPS node.
  4. Apply the configuration by rerunning the Automation Suite installer.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
