- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
AI Trust Layer
Enable custom AI gateways in AI Trust Layer for connecting own AI models through Integration Service on OpenShift.
Enabling custom AI gateways
The Bring-your-own AI gateway feature enables custom connector templates in the AI Trust Layer, allowing you to connect your own AI models through Integration Service's Connector Builder. You must enable this feature during installation by editing the input.json configuration file.
Open
input.jsonand add or edit the following configuration under theplatformcomponent:{ "platform": { "advanced_configuration": { "portal": { "llm_configurations": { "enableByoAiGateway": true } } } } }{ "platform": { "advanced_configuration": { "portal": { "llm_configurations": { "enableByoAiGateway": true } } } } } -
Add or edit the following configuration under the
llmgatewaycomponent:{ "llmgateway": { "advanced_configuration": { "enableByoAiGateway": true } } }{ "llmgateway": { "advanced_configuration": { "enableByoAiGateway": true } } } -
Save
input.jsonand proceed with the installation.
Once enabled, the Create custom connector option in the AI Trust Layer becomes available, allowing you to configure custom LLM connections using Connector Builder templates.
For details, refer to:
