- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Health endpoints
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Health endpoints
Health check endpoints for monitoring Automation Suite services on OpenShift.
To effectively monitor the health of your Automation Suite services, you can use the health endpoints listed in this section. These endpoints allow you to quickly verify if a service is operating correctly.
Platform
https://<automation-suite-fqdn>/pap_/healthhttps://<automation-suite-fqdn>/pdp_/healthhttps://<automation-suite-fqdn>/identity_/.well-known/openid-configurationhttps://<automation-suite-fqdn>/identity_/web/https://<automation-suite-fqdn>/lease_/health/https://<automation-suite-fqdn>/license_/healthhttps://<automation-suite-fqdn>/organization_/healthhttps://<automation-suite-fqdn>/portal_/portal/shallow/healthStatushttps://<automation-suite-fqdn>/audit_/healthhttps://<automation-suite-fqdn>/resourcecatalog_/health
Action Center
https://<automation-suite-fqdn>/actions_/https://<automation-suite-fqdn>/bupproxyservice_/health/readyhttps://<automation-suite-fqdn>/processes_/
Agents
https://<automation-suite-fqdn>/agents_/healthhttps://<automation-suite-fqdn>/agentsruntime_/health
AI Center
https://<automation-suite-fqdn>/aifabric_/ai-apphttps://<automation-suite-fqdn>/aifabric_/ai-deployer/actuator/health/readyhttps://<automation-suite-fqdn>/aifabric_/ai-trainer/actuator/health/readyhttps://<automation-suite-fqdn>/aifabric_/ai-pkgmanager/actuator/health/readyhttps://<automation-suite-fqdn>/aifabric_/ai-helper/actuator/health/readyhttps://<automation-suite-fqdn>/aistorage_/health
Apps
https://<automation-suite-fqdn>/<org-name>/apps_/default/api/v1/default/system-health
Autopilot for Everyone
https://<automation-suite-fqdn>/autopilotforeveryone_/api/health
Autopilot for Developers
https://<automation-suite-fqdn>/autopilotstudio_/alivehttps://<automation-suite-fqdn>/autopilotstudio_/health
Automation Hub
https://<automation-suite-fqdn>/automationhub_/fd-api/v1/pinghttps://<automation-suite-fqdn>/automationstore_/fd-api/v1/ping
Solutions
https://<automation-suite-fqdn>/automationsolutions_/health
Data Service
https://<automation-suite-fqdn>/dataservice_/api/HealthCheck/healthhttps://<automation-suite-fqdn>/dataservice_/assets
https://<automation-suite-fqdn>/du_/api/documentmanager/healthhttps://<automation-suite-fqdn>/du_/api/storage/healthhttps://<automation-suite-fqdn>/du_/api/eventservice/healthhttps://<automation-suite-fqdn>/du_/metering/alivehttps://<automation-suite-fqdn>/du_/ocr/info/readyhttps://<automation-suite-fqdn>/du_/extended-ocr/readyhttps://<automation-suite-fqdn>/du_/classify/MLclassification/info/readyhttps://<automation-suite-fqdn>/du_/svc/formextractor/infohttps://<automation-suite-fqdn>/du_/svc/intelligentkeywords/info
Enterprise Context Service (ECS)
https://<automation-suite-fqdn>/ecs_/health
Healing Agent (Semantic Proxy)
https://<automation-suite-fqdn>/semanticproxy_/health
Insights
https://<automation-suite-fqdn>/insights_/health
Integration Service
https://<automation-suite-fqdn>/connections_/schedulerstatushttps://<automation-suite-fqdn>/connections_/dispatcherstatushttps://<automation-suite-fqdn>/elements_/v1/elements/healthhttps://<automation-suite-fqdn>/elements_/elements/api-v2/tickle
LLM Gateway
https://<automation-suite-fqdn>/llmgateway_/health
LLM Observability
https://<automation-suite-fqdn>/llmops_/healthhttps://<automation-suite-fqdn>/llmops_/tracesruntime/health
Maestro
https://<automation-suite-fqdn>/pims_/api/health
Notification Service
https://<automation-suite-fqdn>/notificationservice_/notificationserviceapi/health/readinesshttps://<automation-suite-fqdn>/notificationservice_/usersubscriptionservice/health/readinesshttps://<automation-suite-fqdn>/notificationservice_/publishermetaservice/health/readiness
Orchestrator
https://<automation-suite-fqdn>/orchestrator_/api/health
Robotube
https://<automation-suite-fqdn>/robotube_/healthz
ScreenPlay (Semantic Proxy)
Studio Governance
https://<automation-suite-fqdn>/roboticsops_/api/health
Studio Web
https://<automation-suite-fqdn>/studio_/backend/healthzhttps://<automation-suite-fqdn>/studio_/typecache/healthz/readinesshttps://<automation-suite-fqdn>/studio_/
Test Manager
https://<automation-suite-fqdn>/testmanager_/api/health/live
Checking service health
To check the health of a specific service, send a request to its corresponding endpoint, as shown in the following example.
curl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/health
A successful response with an HTTP status code 200 indicates that the service is healthy.
- Platform
- Action Center
- Agents
- AI Center
- Apps
- Autopilot for Everyone
- Autopilot for Developers
- Automation Hub
- Solutions
- Data Service
- Document Understanding
- Enterprise Context Service (ECS)
- Healing Agent (Semantic Proxy)
- Insights
- Integration Service
- LLM Gateway
- LLM Observability
- Maestro
- Notification Service
- Orchestrator
- Robotube
- ScreenPlay (Semantic Proxy)
- Studio Governance
- Studio Web
- Test Manager
- Checking service health
