- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Install and configure GitOps tool for managing Automation Suite deployments on OpenShift.
Before proceeding with the OpenShift GitOps Operator installation and configuration, you must install OpenShift Service Mesh and provide all the required permissions to the uipathadmin service account.
For the service mesh installation and configuration instructions, refer to Installing and configuring the service mesh.
For the installation permissions, refer to Granting installation permissions.
You can deploy Automation Suite using either an OpenShift GitOps Operator instance dedicated to the UiPath® applications or a shared OpenShift GitOps Operator instance, if it is already installed and available on your cluster.
We recommend using a dedicated OpenShift GitOps Operator instance to install the Automation Suite applications. This method requires minimum permissions to the other namespaces and cluster resources.
For installation and access details, refer to the following sections:
Provisioning a dedicated GitOps instance
We recommend using a namespace that is different from <uipath> for ArgoCD.
If you use Openshift GitOps version 1.15 or higher and install a dedicated instance of ArgoCD within the <uipath> namespace, the ArgoCD UI will not be accessible due to the network policies in the <uipath> namespace added by the Service Mesh Control Plane. To address this, you must add a network policy, as shown in the following example, to allow the ingress pods to reach the ArgoCD-server pods in the <uipath> namespace.
kind: NetworkPolicy
apiVersion: networking.k8s.io/v1
metadata:
spec:
podSelector:
matchLabels:
app.kubernetes.io/name: argocd-server
ingress:
- namespaceSelector:
matchLabels:
network.openshift.io/policy-group: ingress
policyTypes:
- Ingress
kind: NetworkPolicy
metadata:
spec:
podSelector:
matchLabels:
ingress:
matchLabels:
policyTypes:
- Ingress
To provision a dedicated OpenShift GitOps Operator instance, take the following steps:
If the
<argocd>namespace does not already exist, run the following commands to create it:oc get namespace <argocd> || oc new-project <argocd> oc project <argocd>oc get namespace <argocd> || oc new-project <argocd> oc project <argocd> -
Install the OpenShift GitOps Operator by following the instructions in Installing OpenShift GitOps.
Create a new ArgoCD instance by following the instructions in Setting up a new ArgoCD instance.
Note:In the
specsection described in Enabling replicas for Argo CD server and repo server, you must add the following line:server.route.enabled: trueserver.route.enabled: true -
If you use OpenShift Service Mesh 2.x, patch the ArgoCD deployment so that the service mesh exposes it through an OpenShift route. Skip this step on OpenShift Service Mesh 3.x, where the
maistra.io/expose-routelabel has no effect.oc -n <argocd> patch deployment argocd-server \ -p '{"spec":{"template":{"metadata":{"labels":{"maistra.io/expose-route":"true"}}}}}'oc -n <argocd> patch deployment argocd-server \ -p '{"spec":{"template":{"metadata":{"labels":{"maistra.io/expose-route":"true"}}}}}' -
Create a role so that ArgoCD can manage limit ranges.
Before Automation Suite 2.2510.3, the platform Helm chart shipped a
LimitRangeobject that assigned default resource limits in the<uipath>namespace, so the ArgoCD application controller needed permissions to create and manage it. Starting with 2.2510.3, thisLimitRangeobject was removed from the chart, and the controller only needs thedeleteverb to prune theLimitRangecreated by an earlier version during synchronization.To create the role, take the following steps:
- Save the role configuration that matches your Automation Suite version as a YAML file:
- Automation Suite 2.2510.3 and later (only the
deleteverb is required):kind: Role apiVersion: rbac.authorization.k8s.io/v1 metadata: name: limit-range-manager namespace: <uipath> rules: - apiGroups: [""] resources: ["limitranges"] verbs: ["delete"]kind: Role apiVersion: rbac.authorization.k8s.io/v1 metadata: name: limit-range-manager namespace: <uipath> rules: - apiGroups: [""] resources: ["limitranges"] verbs: ["delete"] - Versions before 2.2510.3:
kind: Role apiVersion: rbac.authorization.k8s.io/v1 metadata: name: limit-range-manager namespace: <uipath> rules: - apiGroups: [""] resources: ["limitranges"] verbs: ["get", "watch", "list", "patch", "update", "create"]kind: Role apiVersion: rbac.authorization.k8s.io/v1 metadata: name: limit-range-manager namespace: <uipath> rules: - apiGroups: [""] resources: ["limitranges"] verbs: ["get", "watch", "list", "patch", "update", "create"]
- Apply the configuration by running the following command. Make sure to replace the
<file_name.yaml>placeholder with the actual name of the YAML file:oc apply -f <file_name.yaml>oc apply -f <file_name.yaml>
Bind the
limit-range-managerrole to theargocdservice account:oc -n <uipath> create rolebinding limit-range-manager-binding --role=limit-range-manager --serviceaccount=<argocd>:argocd-argocd-application-controlleroc -n <uipath> create rolebinding limit-range-manager-binding --role=limit-range-manager --serviceaccount=<argocd>:argocd-argocd-application-controller -
If you enabled TaaS, create a role that grants the ArgoCD application controller write verbs on the
pods/logsubresource. The TaaS pre-install hook creates a role that includes these verbs, and Kubernetes RBAC escalation prevention requires the controller to hold them itself before it can grant them. To create the role, take the following steps:- Save the following role configuration as a YAML file:
kind: Role apiVersion: rbac.authorization.k8s.io/v1 metadata: name: argocd-pod-log-writer namespace: <uipath> rules: - apiGroups: [""] resources: ["pods/log"] verbs: ["create", "update", "patch", "delete"]kind: Role apiVersion: rbac.authorization.k8s.io/v1 metadata: name: argocd-pod-log-writer namespace: <uipath> rules: - apiGroups: [""] resources: ["pods/log"] verbs: ["create", "update", "patch", "delete"] - Apply the configuration by running the following command. Make sure to replace the
<file_name.yaml>placeholder with the actual name of the YAML file:oc apply -f <file_name.yaml>oc apply -f <file_name.yaml> - Bind the
argocd-pod-log-writerrole to theargocdservice account:oc -n <uipath> create rolebinding argocd-pod-log-writer-binding --role=argocd-pod-log-writer --serviceaccount=<argocd>:argocd-argocd-application-controlleroc -n <uipath> create rolebinding argocd-pod-log-writer-binding --role=argocd-pod-log-writer --serviceaccount=<argocd>:argocd-argocd-application-controller
If you enabled Automation Suite Robots, you must enable cluster-wide mode for ArgoCD by taking the following steps:
Important:Cluster-wide mode is required because, by default, the Automation Suite Robots chart deploys a
ClusterRoleandClusterRoleBindingthat a namespaced ArgoCD instance cannot manage. If you are installing with namespace-scoped permissions only, you can skip this step by setting an explicitasrobots.concurrency_limitininput.json; the chart then deploys no cluster-scoped resources. For details, refer to Granting installation permissions without cluster roles.- In
<openshift-gitops>, edit theopenshift-gitops-operatorsubscription resource to include the following environment variable:ARGOCD_CLUSTER_CONFIG_NAMESPACES: <argocd>ARGOCD_CLUSTER_CONFIG_NAMESPACES: <argocd> - Follow the instructions in Using an Argo CD instance to manage cluster-scoped resources.
- In
You must ensure that the ArgoCD instance can manage the
<uipath>namespace if the<uipath>namespace is not the same as the<argocd>namespace:oc label namespace <uipath> argocd.argoproj.io/managed-by=<argocd>oc label namespace <uipath> argocd.argoproj.io/managed-by=<argocd>In this command,
<argocd>is the name of the namespace where you deployed the dedicated ArgoCD instance.After you apply the configuration, restart the ArgoCD
application-controler(statefulset) andserver(deployment). -
You must perform the following steps only if the
<uipath>namespace is not the same as the<argocd>namespace. Create a role to manage the applications in the<argocd>namespace. To create the role, take the following steps:- Save the following role configuration as a YAML file:
apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: uipath-application-manager namespace: <argocd> rules: - apiGroups: - argoproj.io resources: - applications verbs: ["get", "watch", "list", "patch", "update", "create", "delete"]apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: uipath-application-manager namespace: <argocd> rules: - apiGroups: - argoproj.io resources: - applications verbs: ["get", "watch", "list", "patch", "update", "create", "delete"] - Apply the configuration by running the following command. Make sure to replace the
Bind the
uipath-application-managerrole to theuipathadminservice account:oc project <argocd> oc create rolebinding uipath-application-manager \ --role=uipath-application-manager --serviceaccount=<uipath>:uipathadminoc project <argocd> oc create rolebinding uipath-application-manager \ --role=uipath-application-manager --serviceaccount=<uipath>:uipathadmin -
As a cluster administrator, create the
helm-credentialsrepository secret in the<argocd>namespace. This is an ArgoCD repository secret that holds the Helm registry connection details, and ArgoCD reads it to pull the Automation Suite charts.Important:How this secret is managed depends on your Automation Suite version:
- Automation Suite 2.2510.4 and later: the secret is owned by you.
uipathctldoes not manage it and requires no access to it or to the<argocd>namespace — theuipathadminservice account needs no permissions at all there apart from managing ArgoCD applications, which you granted in the previous step. Skip the next step. - Automation Suite 2.2510.3: you create the secret, but
uipathctlstill updates it on every run, souipathadminneedsget,update, andpatchon it. Complete the next step with the 2.2510.3 role. - Versions before 2.2510.3:
uipathctlcreates and manages the secret itself, so you can skip creating it. Complete the next step with the role for versions before 2.2510.3.
Whenever you created the secret, you must also keep it up to date: if the Helm registry credentials change, update the secret yourself, otherwise ArgoCD stops being able to pull the charts.
apiVersion: v1 kind: Secret metadata: name: helm-credentials namespace: <argocd> labels: argocd.argoproj.io/secret-type: repository type: Opaque stringData: name: uipath-helm url: <helm-registry-url> type: helm enableOCI: "true" username: <registry-username> password: <registry-password>apiVersion: v1 kind: Secret metadata: name: helm-credentials namespace: <argocd> labels: argocd.argoproj.io/secret-type: repository type: Opaque stringData: name: uipath-helm url: <helm-registry-url> type: helm enableOCI: "true" username: <registry-username> password: <registry-password>The
stringDatavalues are provided in plain text. For an open registry such asregistry.uipath.com, omit theusernameandpasswordkeys so that ArgoCD connects anonymously. Leaving them blank makes ArgoCD attempt a login and fail with a401error. Alternatively, create the same secret with the CLI:oc -n <argocd> create secret generic helm-credentials \ --from-literal=name=uipath-helm \ --from-literal=url=<helm-registry-url> \ --from-literal=type=helm \ --from-literal=enableOCI=true \ --from-literal=username=<registry-username> \ --from-literal=password=<registry-password> oc -n <argocd> label --overwrite secret helm-credentials argocd.argoproj.io/secret-type=repositoryoc -n <argocd> create secret generic helm-credentials \ --from-literal=name=uipath-helm \ --from-literal=url=<helm-registry-url> \ --from-literal=type=helm \ --from-literal=enableOCI=true \ --from-literal=username=<registry-username> \ --from-literal=password=<registry-password> oc -n <argocd> label --overwrite secret helm-credentials argocd.argoproj.io/secret-type=repository - Automation Suite 2.2510.4 and later: the secret is owned by you.
Automation Suite 2.2510.3 and earlier only. These versions write to the
helm-credentialssecret and look the<argocd>namespace up, souipathadminneeds access to both. Skip this step on 2.2510.4 and later.- Save the role configuration that matches your Automation Suite version as a YAML file:
- Automation Suite 2.2510.3, scoped to the secret you created in the previous step:
apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: argo-secret-role namespace: <argocd> rules: - apiGroups: [""] resources: ["secrets"] resourceNames: ["helm-credentials"] verbs: ["get", "update", "patch"]apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: argo-secret-role namespace: <argocd> rules: - apiGroups: [""] resources: ["secrets"] resourceNames: ["helm-credentials"] verbs: ["get", "update", "patch"] - Versions before 2.2510.3:
apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: argo-secret-role namespace: <argocd> rules: - apiGroups: ["rbac.authorization.k8s.io"] resources: ["roles", "rolebindings"] verbs: ["get", "watch", "list", "patch", "update", "create"] - apiGroups: [""] resources: ["secrets"] verbs: ["get", "watch", "list", "patch", "update", "create"]apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: argo-secret-role namespace: <argocd> rules: - apiGroups: ["rbac.authorization.k8s.io"] resources: ["roles", "rolebindings"] verbs: ["get", "watch", "list", "patch", "update", "create"] - apiGroups: [""] resources: ["secrets"] verbs: ["get", "watch", "list", "patch", "update", "create"]
argo-secret-rolerole and thenamespace-readerrole to theuipathadminservice account:oc project <argocd> oc create rolebinding secret-binding \ --role=argo-secret-role --serviceaccount=<uipath>:uipathadmin oc create rolebinding namespace-reader-rolebinding \ --clusterrole=namespace-reader-clusterrole --serviceaccount=<uipath>:uipathadminoc project <argocd> oc create rolebinding secret-binding \ --role=argo-secret-role --serviceaccount=<uipath>:uipathadmin oc create rolebinding namespace-reader-rolebinding \ --clusterrole=namespace-reader-clusterrole --serviceaccount=<uipath>:uipathadmin
Accessing the dedicated ArgoCD instance
To access ArgoCD, take the following steps:
- Get the host URL:
oc get routes argocd-server -n <argocd> -o jsonpath={.spec.host}; echooc get routes argocd-server -n <argocd> -o jsonpath={.spec.host}; echo - To log in, use
adminas the username and run the following command to get the password:oc -n <argocd> get secrets argocd-cluster \ -o "jsonpath={.data['admin\.password']}" | base64 -d; echooc -n <argocd> get secrets argocd-cluster \ -o "jsonpath={.data['admin\.password']}" | base64 -d; echo
Configuring the private Helm repository and certificates in ArgoCD
To configure the Helm repository in ArgoCD, take the following steps:
- Log in to ArgoCD.
- Navigate to Settings > Repositories > +CONNECT REPO.
- Use VIA HTTPS for the connection method.
- Select Helm as the type.
- Provide a name.
- Choose default as the project.
- Provide the repository URL, username, password, and certificate info.
Important:
When adding the TLS client certificate on the +CONNECT REPO page, the TLS client certificate key becomes a mandatory field. To configure the registry certificate without the TLS client certificate key, take the following steps:
- Navigate to Settings > Repository certificates and known hosts > +ADD TLS CERTIFICATE.
- Add the repository name and TLS certificate in PEM format.
- Enable the OCI checkbox.
- Select Connect.
- Make sure that the connection status is Successful.
Configuring a shared GitOps instance
If your platform team has not already provisioned the shared OpenShift GitOps Operator instance, take the following installation and configuration steps:
Create the
<uipath>namespace:oc get namespace <uipath> || oc new-project <uipath> oc project <uipath>oc get namespace <uipath> || oc new-project <uipath> oc project <uipath> -
Install the OpenShift GitOps Operator by following the instructions in Installing OpenShift GitOps. This installation comes with the default ArgoCD instance, named
openshift-gitops, in the<openshift-gitops>namespace. -
Enable cluster-wide mode for ArgoCD by taking the following steps:
- In
<openshift-gitops>, edit theopenshift-gitops-operatorsubscription resource to include the following environment variable:ARGOCD_CLUSTER_CONFIG_NAMESPACES: <openshift-gitops>ARGOCD_CLUSTER_CONFIG_NAMESPACES: <openshift-gitops> - Follow the instructions in Using an ArgoCD instance to manage cluster-scoped resources.
- In
Make sure that the
openshift-gitopsArgoCD instance can manage the<uipath>namespace:oc label namespace <uipath> argocd.argoproj.io/managed-by=openshift-gitopsoc label namespace <uipath> argocd.argoproj.io/managed-by=openshift-gitopsAfter you apply the configuration, restart the ArgoCD
openshift-gitops-application-controller(statefulset) andopenshift-gitops-server(deployment). -
maistra.io/expose-routelabel has no effect.oc -n <uipath> patch deployment argocd-server \ -p '{"spec":{"template":{"metadata":{"labels":{"maistra.io/expose-route":"true"}}}}}'oc -n <uipath> patch deployment argocd-server \ -p '{"spec":{"template":{"metadata":{"labels":{"maistra.io/expose-route":"true"}}}}}' -
Create an ArgoCD project for the UiPath® application:
apiVersion: argoproj.io/v1alpha1 kind: AppProject metadata: name: uipath namespace: <openshift-gitops> spec: description: Appproject to managed and deploy uipath applications clusterResourceWhitelist: - group: '*' kind: '*' destinations: - namespace: <uipath> server: https://kubernetes.default.svc - namespace: <istio-system> server: https://kubernetes.default.svc sourceNamespaces: - <openshift-gitops> sourceRepos: - '*'apiVersion: argoproj.io/v1alpha1 kind: AppProject metadata: name: uipath namespace: <openshift-gitops> spec: description: Appproject to managed and deploy uipath applications clusterResourceWhitelist: - group: '*' kind: '*' destinations: - namespace: <uipath> server: https://kubernetes.default.svc - namespace: <istio-system> server: https://kubernetes.default.svc sourceNamespaces: - <openshift-gitops> sourceRepos: - '*' -
Bind the
limit-range-managerrole to theargocdservice account:oc -n <uipath> create rolebinding limit-range-manager-binding --role=limit-range-manager --serviceaccount=<openshift-gitops>:openshift-gitops-argocd-application-controlleroc -n <uipath> create rolebinding limit-range-manager-binding --role=limit-range-manager --serviceaccount=<openshift-gitops>:openshift-gitops-argocd-application-controller -
<openshift-gitops>namespace:apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: uipath-application-manager namespace: <openshift-gitops> rules: - apiGroups: - argoproj.io resources: - applications verbs: ["get", "watch", "list", "patch", "update", "create"]apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: uipath-application-manager namespace: <openshift-gitops> rules: - apiGroups: - argoproj.io resources: - applications verbs: ["get", "watch", "list", "patch", "update", "create"] -
Bind the
uipath-application-managerrole to theuipathadminservice account:oc project <openshift-gitops> oc create rolebinding uipath-application-manager \ --role=uipath-application-manager --serviceaccount=<uipath>:uipathadminoc project <openshift-gitops> oc create rolebinding uipath-application-manager \ --role=uipath-application-manager --serviceaccount=<uipath>:uipathadmin -
helm-credentialsrepository secret in the<openshift-gitops>namespace. This is an ArgoCD repository secret that holds the Helm registry connection details, and ArgoCD reads it to pull the Automation Suite charts.Important:How this secret is managed depends on your Automation Suite version:
uipathctldoes not manage it and requires no access to it or to the<openshift-gitops>namespace — theuipathadminservice account needs no permissions at all there apart from managing ArgoCD applications, which you granted in the previous step. Skip the next step. - Automation Suite 2.2510.3: you create the secret, but
apiVersion: v1 kind: Secret metadata: name: helm-credentials namespace: <openshift-gitops> labels: argocd.argoproj.io/secret-type: repository type: Opaque stringData: name: uipath-helm url: <helm-registry-url> type: helm enableOCI: "true" username: <registry-username> password: <registry-password>apiVersion: v1 kind: Secret metadata: name: helm-credentials namespace: <openshift-gitops> labels: argocd.argoproj.io/secret-type: repository type: Opaque stringData: name: uipath-helm url: <helm-registry-url> type: helm enableOCI: "true" username: <registry-username> password: <registry-password>The
stringDatavalues are provided in plain text. For an open registry such asregistry.uipath.com, omit theusernameandpasswordkeys so that ArgoCD connects anonymously. Leaving them blank makes ArgoCD attempt a login and fail with a401error. Alternatively, create the same secret with the CLI:oc -n <openshift-gitops> create secret generic helm-credentials \ --from-literal=name=uipath-helm \ --from-literal=url=<helm-registry-url> \ --from-literal=type=helm \ --from-literal=enableOCI=true \ --from-literal=username=<registry-username> \ --from-literal=password=<registry-password> oc -n <openshift-gitops> label --overwrite secret helm-credentials argocd.argoproj.io/secret-type=repositoryoc -n <openshift-gitops> create secret generic helm-credentials \ --from-literal=name=uipath-helm \ --from-literal=url=<helm-registry-url> \ --from-literal=type=helm \ --from-literal=enableOCI=true \ --from-literal=username=<registry-username> \ --from-literal=password=<registry-password> oc -n <openshift-gitops> label --overwrite secret helm-credentials argocd.argoproj.io/secret-type=repository - Automation Suite 2.2510.4 and later: the secret is owned by you.
helm-credentialssecret and look the<openshift-gitops>namespace up, souipathadminneeds access to both. Skip this step on 2.2510.4 and later.- Save the role configuration that matches your Automation Suite version as a YAML file:
apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: argo-secret-role namespace: <openshift-gitops> rules: - apiGroups: [""] resources: ["secrets"] resourceNames: ["helm-credentials"] verbs: ["get", "update", "patch"]apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: argo-secret-role namespace: <openshift-gitops> rules: - apiGroups: [""] resources: ["secrets"] resourceNames: ["helm-credentials"] verbs: ["get", "update", "patch"] - Versions before 2.2510.3:
apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: argo-secret-role namespace: <openshift-gitops> rules: - apiGroups: ["rbac.authorization.k8s.io"] resources: ["roles", "rolebindings"] verbs: ["get", "watch", "list", "patch", "update", "create"] - apiGroups: [""] resources: ["secrets"] verbs: ["get", "watch", "list", "patch", "update", "create"]apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: argo-secret-role namespace: <openshift-gitops> rules: - apiGroups: ["rbac.authorization.k8s.io"] resources: ["roles", "rolebindings"] verbs: ["get", "watch", "list", "patch", "update", "create"] - apiGroups: [""] resources: ["secrets"] verbs: ["get", "watch", "list", "patch", "update", "create"]
argo-secret-rolerole and thenamespace-readerrole to theuipathadminservice account:oc project <openshift-gitops> oc create rolebinding secret-binding \ --role=argo-secret-role --serviceaccount=<uipath>:uipathadmin oc create rolebinding namespace-reader-rolebinding \ --clusterrole=namespace-reader-clusterrole --serviceaccount=<uipath>:uipathadminoc project <openshift-gitops> oc create rolebinding secret-binding \ --role=argo-secret-role --serviceaccount=<uipath>:uipathadmin oc create rolebinding namespace-reader-rolebinding \ --clusterrole=namespace-reader-clusterrole --serviceaccount=<uipath>:uipathadmin
In addition to completing the steps to configure the shared ArgoCD instance for the Automation Suite installation, you must add the following parameters to the input.json file:
"argocd": {
"project": "<uipath>"
"argocd": {
Accessing the shared ArgoCD instance
- Get the host URL by running the following commands:
oc get routes openshift-gitops-server -n <openshift-gitops> -o jsonpath={.spec.host}; echooc get routes openshift-gitops-server -n <openshift-gitops> -o jsonpath={.spec.host}; echo - To log in, use
adminas the username and run the following command to get the password:oc -n <openshift-gitops> get secrets openshift-gitops-cluster \ -o "jsonpath={.data['admin\.password']}" | base64 -d; echooc -n <openshift-gitops> get secrets openshift-gitops-cluster \ -o "jsonpath={.data['admin\.password']}" | base64 -d; echo
- Log in to ArgoCD.
- Provide a name.
- Choose uipath as the project. uipath is the name of the ArgoCD project you created for the UiPath® application.
Important:
- Select Connect.
Configuring ArgoCD for multiple installations in a single cluster
To configure ArgoCD for multiple Automation Suite installations in a single OpenShift cluster, follow these steps:
- Check if all the services of ArgoCD are up and running. You can run the following command to monitor all the pods:
oc get pods -n <argocd>oc get pods -n <argocd> - Once all services are up and running, you can use the following command sequentially to patch ArgoCD's permissions. This allows ArgoCD to manage different application namespaces where Automation Suite is installed:
oc patch appprojects.argoproj.io default -n <argocd> --type='merge' -p '{"spec": {"sourceNamespaces": ["*"]}}' oc patch configmaps argocd-cmd-params-cm -n <argocd> --type='merge' -p '{"data": {"application.namespaces": "*"}}' oc rollout restart -n <argocd> deployment argocd-server oc rollout restart -n <argocd> statefulset argocd-application-controlleroc patch appprojects.argoproj.io default -n <argocd> --type='merge' -p '{"spec": {"sourceNamespaces": ["*"]}}' oc patch configmaps argocd-cmd-params-cm -n <argocd> --type='merge' -p '{"data": {"application.namespaces": "*"}}' oc rollout restart -n <argocd> deployment argocd-server oc rollout restart -n <argocd> statefulset argocd-application-controller
- Provisioning a dedicated GitOps instance
- Accessing the dedicated ArgoCD instance
- Configuring the private Helm repository and certificates in ArgoCD
- Configuring a shared GitOps instance
- Accessing the shared ArgoCD instance
- Configuring ArgoCD for multiple installations in a single cluster
