Converting an existing installation to multi-site setup
Convert standalone Automation Suite cluster to primary cluster in multi-site setup on OpenShift.
You can convert an existing installation into multi-site by taking the following steps:
  1. Convert the standalone Automation Suite cluster into the primary cluster. For details, refer to Converting a standalone cluster into a primary cluster.
  2. Install secondary Automation Suite cluster. For details, refer to Disaster Recovery - Installing the secondary cluster.
Note:
Ensure that the certificates are the same on the primary and secondary clusters. This check is not performed or enforced automatically.
Converting a standalone cluster into a primary cluster​
To convert an existing Automation Suite cluster into a primary cluster of the multi-site deployment, take the following steps:
  1. Update input.json. Add or update fqdn, cluster_fqdn, and enable multisite.
    "fqdn" : "<global traffic manager fqdn>"
    "cluster_fqdn": "<fqdn of the primary cluster>",
    "multisite": {
        "enabled": true,
        "primary": true
    "multisite": {
        "enabled": true,
        "primary": true
    For details, refer to Active/Passive configurations.
    Update the TLS certificate section to configure the new certificate, ensuring it meets the requirements outlined in the section.
    Note:
    It is recommended to keep the FQDN of your existing Automation Suite setup to avoid reconfiguring all your robots.
  2. Reapply the manifest by running the following command:
    uipathctl manifest apply input.json --versions versions.json
  3. If Istio is managed externally (not by uipathctl), update the following parameters in the WASM plugin configuration:
    • fqdn - Change the value from the cluster_fqdn to the traffic manager FQDN.
    • uipath_service_namespace - Set this to the same value as the namespace field in input.json.If these parameters are not updated, Orchestrator may display errors such as:
    • URL is invalid
    • Routing error occurs in the WASM plugin: error status returned by host: bad argument
  • Converting a standalone cluster into a primary cluster​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
