Performing database maintenance
Perform regular database maintenance including backups, integrity checks, and old data cleanup in Automation Suite.
It is important to keep your databases free from clutter. To do this, we recommend performing the following operations:
Using SQL Server Maintenance Solution​
SQL Server Maintenance Solution is a set of scripts that enable you to run backups, integrity checks, and index and statistics maintenance on all editions of Microsoft SQL Server, starting with the 2005 version. For details, refer to the SQL Server Maintenance Solution GitHub project.
Backing up the database​
We recommend implementing regular backups of the SQL Server database, such as full weekly or daily incremental backups.
Additionally, we recommend using the DatabaseBackup stored procedure that is created using the script described in SQL Server Backup.
Deleting old data periodically​
Shared Suite Capabilities​
Create a separate database in which to save items before you delete them. This database acts as an archive for the items you may need to store for certain reasons, such as audits.
  1. Create a new database called, for example, UiPathArchives:
    create database UiPathArchives
  2. Create the following backup tables:
    ArchiveAuditEvent with the same structure as the AuditEvent table:
    SELECT * INTO [UiPathArchives].[dbo].[ArchiveAuditEvent] from [AutomationSuite_Platform].[adt].[AuditEvent] where 1 = 2
  3. Archive the data.
    To archive audit event records, use the following example script:
       DECLARE @NumberOfDaysToKeep INT
       DECLARE @CurrentDate DATETIME
       -- Specify the number of days
       SET @NumberOfDaysToKeep = 60
       -- Archive the list of audit event records that you want to delete
       SET @CurrentDate = GetDate()
       BEGIN TRANSACTION
       INSERT INTO [UiPathArchives].[dbo].[ArchiveAuditEvent]
       SELECT
       [Id],[CreatedOn],[Version],[OrganizationId],[Source],[Category],[Action],[IsUserEvent],
       [UserId],[FullName],[Email],[DetailsVersion],[Details],[OperationId]
       FROM [adt].[AuditEvent]
       WHERE DateDiff(day, CreatedOn, @CurrentDate) > @NumberOfDaysToKeep
       -- Delete the audit events
       DELETE FROM [adt].[AuditEvent]
       WHERE EXISTS (SELECT 1 FROM [UiPathArchives].[dbo].[ArchiveAuditEvent] WHERE Id = [adt].[AuditEvent].[Id])
       COMMIT TRANSACTION
       BEGIN TRANSACTION
       SELECT
       COMMIT TRANSACTION
    Old data is copied to these archives prior to being deleted when using the following query.
  4. Delete data from the table.
    Important:
    Before running the following script, make sure to adapt it to your environment.
    Audit events:
       declare @NumberOfDaysToKeep int
       declare @CurrentDate datetime
       -- Create temporary table with the list of audit event records that you want to delete
       SELECT
       INTO #TempAuditRecordsToDelete
       -- Review the audit event records to be deleted
       SELECT * FROM #TempAuditRecordsToDelete
       BEGIN TRANSACTION
       WHERE EXISTS (SELECT 1 FROM #TempAuditRecordsToDelete WHERE Id = [adt].[AuditEvent].[Id])
       DROP TABLE #TempAuditRecordsToDelete
       COMMIT TRANSACTION
       SELECT
       BEGIN TRANSACTION
       COMMIT TRANSACTION
Identity Server​
Note:
The database maintenance script provided in this section is supported only when using SQL Server on-premises. It does not work with Azure SQL. If your Automation Suite deployment uses Azure SQL, do not run this script.
  1. Create a new database called, for example, UiPathIdentityArchives:
    create database UiPathIdentityArchives
    ArchiveLoginAttempts with the same structure as the UserLoginAttempts table:
    select * into [UiPathIdentityArchives].[dbo].[ArchiveUserLoginAttempts] from [AutomationSuite_Platform].[identity].[UserLoginAttempts] where 1=2
  3. Delete data from the table.
    Important:
    To delete login attempts older than 60 days, for example, use the following query. It can be executed manually or scheduled in an SQL Server Job.
       set @NumberOfDaysToKeep = 60
       if OBJECT_ID('[UiPathIdentityArchives].[dbo].[UserLoginAttemps]') = NULL
         begin select * into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] from [identity].UserLoginAttempts where 1=2 end
       begin transaction
         set identity_insert [UiPathIdentityArchives].[dbo].[UserLoginAttemps] on
         insert into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] ([Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName])
           select [Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName]
             from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep
         delete from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep
       commit transaction
       begin transaction
       commit transaction
Orchestrator​
For details on how to periodically delete old data from the Orchestrator database, refer to Cleaning up the Orchestrator database.
Automation Hub​
Automation Hub relies on its historical data for runtime views and dashboards, and due to its nature, it does not have the concept of cleaning up old data. Similar to other services, it is recommended to regularly back up the Automation Hub database through methods such as full weekly backups or daily incremental backups.
Process Mining​
Process Mining on Automation Suite provides built-in automatic database cleanup ensuring optimal efficiency and performance. This guarantees the regular removal of unnecessary data, keeping your database cleaned up and functional without the need for any manual actions to free up resources.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
