- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Configure maximum HTTP request body size in Orchestrator using customconfig in Automation Suite on OpenShift.
You can configure the maximum request size in the orchestrator-customconfig config map using a tool such as kubectl.
For details, refer to Custom Orchestrator configuration.
The default value for the maximum request size is 300 MB, but you can edit it in the values.json file. The Orchestrator deployment should restart automatically after this configuration change.
"Kestrel": {
"Limits": {
"MaxRequestBodySize": 314572800
"Kestrel": {
"Limits": {
The values.json file in the orchestrator-customconfig config map may also contain other values, such as AppSettings. You must not remove any other settings when configuring the maximum request size.
"Kestrel": {
"AppSettings": {
"Kestrel": {
"AppSettings": {
