- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Solutions for AI Center and Document Understanding pods failing with TLS certificate verification enabled in Automation Suite on OpenShift.
When database TLS certificate verification is enabled (trustservercertificate=false in the SQL connection string), some AI Center and Document Understanding pods may get stuck in Init:CrashLoopBackOff. The await-migration-completion init container fails to connect to the database, with TLS/SSL handshake errors in the logs.
Solution
To address the issue, take the following steps:
Disable Auto-Sync for AI Center and Document Understanding in ArgoCD.
Manually add the following volume mounts to the
await-migration-completioninit container in each affected deployment.For
aistorageandaistorage-cleanup:- mountPath: /etc/pki/ca-trust/extracted/java/ name: java - mountPath: /etc/pki/ca-trust/extracted/edk2/ name: edk2 - mountPath: /etc/pki/ca-trust/extracted/pem/ name: pem - mountPath: /etc/pki/ca-trust/extracted/openssl/ name: openssl - mountPath: /etc/pki/ca-trust/source/anchors/ name: cert-location- mountPath: /etc/pki/ca-trust/extracted/java/ name: java - mountPath: /etc/pki/ca-trust/extracted/edk2/ name: edk2 - mountPath: /etc/pki/ca-trust/extracted/pem/ name: pem - mountPath: /etc/pki/ca-trust/extracted/openssl/ name: openssl - mountPath: /etc/pki/ca-trust/source/anchors/ name: cert-locationFor
du-digitizeranddu-digitizer-cleanup:- mountPath: /etc/ssl/certs name: cert-trust-store - mountPath: /usr/local/share/ca-certificates name: cert-location- mountPath: /etc/ssl/certs name: cert-trust-store - mountPath: /usr/local/share/ca-certificates name: cert-locationNote:These volumes are already defined at the pod level and only need to be mounted into the init container.
Enable Auto-Sync again.
