- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Compatibility matrix
Third-party software and OpenShift versions compatible with Automation Suite 2.2510 installations.
OpenShift third-party component compatibility
The following table lists the third-party software compatible with the latest version of Automation Suite on OpenShift.
| Prerequisites for OpenShift | Compatible versions |
| Redis | Version 6, 7, and 84 |
| Microsoft SQL Server | Microsoft SQL Server 2019 and 2022, Standard and Enterprise editions. |
| PostgreSQL (required by Process Mining, TaaS, and A4D - each uses its own dedicated database) | PostgreSQL 12.x to 16.x are supported. It is recommended to use the most recent version of PostgreSQL within this range for optimal compatibility and performance. |
| OpenShift GitOps Operator | 1.21.1 |
| OpenShift Service Mesh |
| OpenShift Redis Enterprise Operator | 7.8.2-6, 7.4.6-2, 7.22.0-7, 7.22.0-17, 8.0.10-22.0, 8.2.0-12.0 |
| OpenShift Redis Community Operator (by OpsTree Solutions) | 0.15.1 |
| Nvidia GPU Operator (by Nvidia Corporation) |
1 Available starting with Automation Suite 2.2510.4.
2 Available starting with Automation Suite 2.2510.1.
3 Available starting with Automation Suite 2.2510.2.
4 Support for Redis 7 and 8 is available starting with Automation Suite 2.2510.4.
OpenShift compatibility
To receive UiPath® support for a particular Automation Suite Cumulative Update (CU), you must use both an Automation Suite version and an OpenShift version that are currently supported.
The support calendar for Automation Suite is available in the Product lifecycle section of the Overview guide. For the OpenShift support calendar, refer to the OpenShift documentation.
Updating your OpenShift cluster to a supported version may require updating Automation Suite to a newer CU. For example, if you are on Automation Suite 2.2510.0, the last supported version for your cluster is OpenShift 4.19. When this version reaches its end of life, you must update your cluster to a newer OpenShift version. This also requires updating to a newer Automation Suite CU.
The following table lists the OpenShift versions compatible with each Automation Suite 2.2510.x CU.
| Automation Suite version | Compatible OpenShift versions |
| 2.2510.4 | 4.17, 4.18, 4.19, 4.20, 4.21, 4.22 |
| 2.2510.3 | 4.17, 4.18, 4.19, 4.20, 4.21, 4.22 |
| 2.2510.2 | 4.17, 4.18, 4.19, 4.20 |
| 2.2510.1 | 4.16, 4.17, 4.18, 4.19 |
| 2.2510.0 | 4.16, 4.17, 4.18, 4.19 |
If you are using OpenShift 4.20, you must configure CSI driver tolerations for ODF. For details, refer to Configuring CSI driver tolerations for ODF 4.20.
