Migrating standalone products to Automation Suite
Migrate standalone UiPath products to Automation Suite on OpenShift.
To migrate your standalone Orchestrator data to Automation Suite, you can use the UiPath Automation Cloud™ Migration Tool. The tool helps you run a single tenant migration process and copy strictly the entities present in your standalone Orchestrator. The tool retrieves these entities from standalone Orchestrator over API and then writes them in Automation Suite over API.
The tool can migrate to either Automation Cloud or Automation Suite, but this guide describes the process of migrating to Automation Suite. For instructions on migrating to Automation Cloud, refer to the Automation Cloud documentation instead.
You can only use the Automation Cloud Migration Tool if:
  • your standalone Orchestrator version is 2019.10.x, 2020.10.x, 2021.4.x, 2021.10.x, or later.
  • your Automation Suite version is 2021.10.x or later.
Before you run a tenant migration, review the details from the following table to understand the scope, results, and requirements.
CategoryDescription
Scope- Tenants: Only the targeted tenant. You can run the tool multiple times to migrate several or all tenants.
- Entities: Only migrates the Orchestrator entities listed in Entities being migrated.
- Orchestrator configurations: Some Orchestrator settings are migrated, but not all. For details, refer to Entities being migrated.
OutcomeAll your entities are copied over to Orchestrator, but Orchestrator in Automation Suite uses the default Automation Suite configuration.
To get to the same setup you had in your standalone installation, you must perform a first-time configuration of Automation Suite, which you can do at any time - before or after migration.
PrerequisitesSupports direct migration from any supported standalone Orchestrator version 2019.4.
Organization hierarchyYou can migrate your tenants to the same organization, or to several organizations, as needed.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
