- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Configure Orchestrator manifest and custom configuration for appSettings and NLog in Automation Suite.
Manifest configuration
Follow these steps to edit the Orchestrator manifest configuration:
- Edit the
input.jsonfile. For details, refer to Configuring input.json. - Add or edit the desired settings in the
orchestratorsection. - Run the following command:
uipathctl manifest apply input.json --versions versions.json --kubeconfig kubeconfig.yaml --only orchestratoruipathctl manifest apply input.json --versions versions.json --kubeconfig kubeconfig.yaml --only orchestrator
Custom Orchestrator configuration
You can use the following command to edit the Orchestrator custom configuration for both appSettings and NLog:
uipathctl config orchestrator
Custom Orchestrator scenarios
You can modify various Orchestrator parameters using uipathctl. This enables the following configuration scenarios:
