Rotating Blob Storage Credentials
Rotate blob storage credentials for Process Mining in Automation Suite on OpenShift.
Introduction​
To rotate the blob storage credentials for Process Mining in Automation Suite an administrator will need to have access to the Kubernetes cluster secrets using either kubectl, oc, lens, or another tool. The stored secrets must be updated with the new credentials, and the pods for Airflow and Process Mining need to be restarted to make sure all pods for these service receive the new credentials.
Note:
The storage credentials need to be updated in the <uipath> namespace.
Note:
The stored secret values are base 64 encoded. If using kubectl you will need to encode the values before updating them in the cluster. If using Lens (k8slens) then the Lens tooling can do the decode/encode automatically.
Examples​
The following example shows how to update secrets:
oc patch secret processmining-external-storage-secret -n <uipath> -p "{\"data\":{\"ACCOUNTKEY\":\"<new_key_b64>\"}}"
Ceph Secrets​
UiPath Namespace
  • processmining-service-rook-ceph-secret.OBJECT_STORAGE_ACCESSKEY
  • processmining-service-rook-ceph-secret.OBJECT_STORAGE_SECRETKEY
Minio Secrets​
UiPath Namespace
  • processmining-external-storage-secret.ACCESSKEY
  • processmining-external-storage-secret.SECRETKEY
S3 Secrets​
UiPath Namespace
Azure Secrets​
UiPath Namespace
  • processmining-external-storage-secret.ACCOUNTNAME
  • processmining-external-storage-secret.ACCOUNTKEY
Note:
Azure connection string is URL encoded; the string will need to be decoded, have the access key updated, then re-encoded.
urlencode -d "wasb%3A%2F%2Fazureuser%40%3Fextra__wasb__connection_string%3DDefaultEndpointsProtocol%3Dhttps%3BEndpointSuffix%3Dcore.windows.net%3BAccountName%3Dazureuser%3BAccountKey%3DACCOUNT_KEY%3BBlobEndpoint%3Dhttps%3A%2F%2Fexample.blob.core.windows.net%2F%3BFileEndpoint%3Dhttps%3A%2F%2Fexample.file.core.windows.net%2F%3BQueueEndpoint%3Dhttps%3A%2F%2Fexample.queue.core.windows.net%2F%3BTableEndpoint%3Dhttps%3A%2F%2Fexample.table.core.windows.net%2F%26extra__wasb__sas_token%3D%26extra__wasb__shared_access_key%3D%26extra__wasb__tenant_id%3D"
urlencode "wasb://azureuser@?extra__wasb__connection_string=DefaultEndpointsProtocol=https;EndpointSuffix=core.windows.net;AccountName=azureuser;AccountKey=ACCOUNT_KEY;BlobEndpoint=https://example.blob.core.windows.net/;FileEndpoint=https://example.file.core.windows.net/;QueueEndpoint=https://example.queue.core.windows.net/;TableEndpoint=https://example.table.core.windows.net/&extra__wasb__sas_token=&extra__wasb__shared_access_key=&extra__wasb__tenant_id="
  • Introduction​
  • Examples​
  • Ceph Secrets​
  • Minio Secrets​
  • S3 Secrets​
  • Azure Secrets​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
