- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Update Orchestrator appSettings configuration using uipathctl commands in Automation Suite on OpenShift.
The Orchestrator configuration consists of an array of Kubernetes config maps and secrets that are loaded in a specific order, and placed in the appSettings section of config maps.
The latest configuration is loaded from the orchestrator-customconfig config map. Any newly loaded configuration overwrites all existing settings that have the same key.
To display the current custom Orchestrator configuration, use the config orchestrator get-config uipathctl command:
uipathctl config orchestrator get-config --app-settings
"key":"value"
"key":"value"
The uipathctl commands needed for configuring appSettings are:
uipathctl config orchestrator get-config --app-settings- Exports the current configuration in a key-value pair json file, ready for editing. For details, refer to the uipathctl config orchestrator get-config section.uipathctl config orchestrator update-config --app-settings appsettings.json- Updates the configuration with your changes. For details, refer to the uipathctl config orchestrator update-config section.
Export the current custom
appSettingsconfiguration to a json file using this command:uipathctl config orchestrator get-config --app-settings > appsettings.jsonuipathctl config orchestrator get-config --app-settings > appsettings.json -
Edit the exported
appsettings.jsonfile as needed. You can add, remove, or change any of its settings, as shown in the following example:{ "Triggers.DisableWhenFailedCount": "20", "Triggers.JobsCountStrategy": "NoLimit" }{ "Triggers.DisableWhenFailedCount": "20", "Triggers.JobsCountStrategy": "NoLimit" }Note:You must export the file again every time you need to make a change, since the update overwrites all settings.
Update the
appSettingsconfiguration using this command:uipathctl config orchestrator update-config --app-settings appsettings.json orchestrator config updateduipathctl config orchestrator update-config --app-settings appsettings.json orchestrator config updated
