Configuring the Insights custom security context
Configure custom security context for Insights to enable Chromium SUID Sandbox features on OpenShift.
The Insights application has multiple features that use the Chromium Linux SUID Sandbox. Thus, while the elevated access is not required for the installation of the Insights application itself, it is essential for specific feature functionality.
  1. Save the configuration file as a YAML file and execute the following command. Make sure to replace the <file_name.yaml> placeholder with the actual name used for your YAML file: oc apply -f <file_name.yaml>.
    allowedCapabilities:
      - SETUID
    apiVersion: security.openshift.io/v1
    fsGroup:
      type: MustRunAs
    groups: []
    kind: SecurityContextConstraints
    metadata:
    readOnlyRootFilesystem: false
    runAsUser:
      type: MustRunAsRange
    seLinuxContext:
      type: MustRunAs
    supplementalGroups:
      type: RunAsAny
    users: []
    volumes:
      - configMap
      - csi
      - downwardAPI
      - emptyDir
      - ephemeral
      - persistentVolumeClaim
      - projected
      - secret
      - SETUID
    fsGroup:
      type: MustRunAs
    groups: []
    metadata:
    runAsUser:
    seLinuxContext:
      type: MustRunAs
    supplementalGroups:
      type: RunAsAny
    users: []
    volumes:
      - configMap
      - csi
      - downwardAPI
      - emptyDir
      - ephemeral
      - projected
      - secret
  2. Save the following in a file named <file_name.yaml> to create a role to access the Security Context Constraint:
    kind: Role
    apiVersion: rbac.authorization.k8s.io/v1
    metadata:
      namespace: <uipath>
    rules:
      - verbs:
          - use
        apiGroups:
          - security.openshift.io
        resources:
          - securitycontextconstraints
        resourceNames:
          - insights-scc
    kind: Role
    metadata:
      namespace: <uipath>
    rules:
      - verbs:
          - use
        apiGroups:
        resources:
        resourceNames:
          - insights-scc
    Create a role to access the Security Context Constraint by executing the following command: oc apply -f <file_name.yaml>. Make sure to replace the <file_name.yaml> placeholder with the actual name used for your YAML file.
  3. Save the following in a file named <file_name.yaml> to create a role-binding to bind the previously defined role to the Insights service account:
    kind: RoleBinding
    metadata:
      namespace: <uipath>
    subjects:
      - kind: ServiceAccount
        namespace: <uipath>
    roleRef:
      apiGroup: rbac.authorization.k8s.io
      kind: Role
    kind: RoleBinding
    metadata:
      namespace: <uipath>
    subjects:
        namespace: <uipath>
    roleRef:
      kind: Role
    Create a role-binding to bind the previously defined role to the Insights service account by executing the following command: oc apply -f <file_name.yaml>. Make sure to replace the <file_name.yaml> placeholder with the actual name used for your YAML file.
  4. Navigate to ArgoCD and disable Auto sync for Insights.
  5. Update the security context for the Insights Looker, located within the Insights Looker statefulset. Add the SETUID capabilities:
    capabilities:
     add:
      - SETUID
     drop:
      - ALL
    capabilities:
     add:
      - SETUID
     drop:
      - ALL
  6. Rollout restart statefulset:
    oc -n <uipath> rollout restart statefulset/insights-insightslooker
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
