- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Remapping the organization IDs
Remap organization IDs when migrating from standalone Insights to Automation Suite.
To migrate from standalone Insights to Automation Suite, you must remap the organization IDs in the following tables:
[Id] [int] NOT NULL,
[Key] [nvarchar](128) NOT NULL,
[Name] [nvarchar](128) NOT NULL,
[IsActive] [bit] NOT NULL,
[IsDeleted] [bit] NOT NULL,
[OrganizationId] [nvarchar](128) NULL,
CONSTRAINT [PK_dbo.Tenants] PRIMARY KEY CLUSTERED
CREATE TABLE [insightsintegrations].[TenantServiceIntegrations](
[Id] [uniqueidentifier] NOT NULL,
[TenantId] [uniqueidentifier] NOT NULL,
[OrganizationId] [uniqueidentifier] NOT NULL,
[ServiceName] [int] NOT NULL,
[Status] [int] NOT NULL,
[CreationTime] [datetime2](7) NOT NULL,
[LastUpdatetime] [datetime2](7) NOT NULL,
CONSTRAINT [PK_TenantServiceIntegrations] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[GroupRoles](
[GroupId] [uniqueidentifier] NOT NULL,
[RoleId] [uniqueidentifier] NOT NULL,
CONSTRAINT [PK_GroupRoles] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Groups](
[Name] [nvarchar](max) NULL,
[Email] [nvarchar](max) NULL,
CONSTRAINT [PK_Groups] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Roles](
[TenantId] [uniqueidentifier] NULL,
[Resource] [nvarchar](max) NULL,
CONSTRAINT [PK_Roles] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[TenantGroups](
[TimeProcessed] [datetime2](7) NULL,
[LastUpdateTime] [datetime2](7) NOT NULL,
CONSTRAINT [PK_TenantGroup] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Tenants](
CONSTRAINT [PK_Tenants] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Users](
[IsDeleted] [bit] NULL,
CONSTRAINT [PK_Users] PRIMARY KEY CLUSTERED
CREATE TABLE [insightsprovisioning].[TenantInstances](
[ServiceType] [nvarchar](max) NULL,
[State] [int] NOT NULL,
[TenantName] [nvarchar](max) NULL,
CONSTRAINT [PK_TenantInstances] PRIMARY KEY CLUSTERED
CREATE TABLE [read].[HASHKEYS](
[hashkey] [bigint] NOT NULL,
[tenantkey] [nvarchar](128) NOT NULL,
[tenantname] [nvarchar](256) NULL,
[organizationid] [nvarchar](128) NULL,
[status] [int] NULL
[status] [int] NULL
[dbo].[Tenants]
[read].[HASHKEYS]
[dbo].[Tenants]
[read].[HASHKEYS]
Tip:
This is an example on how to update the tables:
--- Script to replace MSI organization ID with AS organization ID.
--- Please update the following DECLARE statements with your corresponding MSI org ID and AS org ID before executing this script.
DECLARE @msi_organization_id nvarchar(500) = upper('687db434-ce5c-4058-bc0b-3ed3fa23882b');
DECLARE @as_organization_id nvarchar(500) = upper('AA259F1A-5828-4608-AF71-27177A7831B8');
DECLARE @msi_resource nvarchar(500) = lower('insights/687db434-ce5c-4058-bc0b-3ed3fa23882b/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
DECLARE @as_resource nvarchar(500) = lower('insights/aa259f1a-5828-4608-af71-27177a7831b8/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
SELECT * FROM [dbo].[Tenants];
UPDATE [dbo].[Tenants]
SET OrganizationId = lower(@as_organization_id)
WHERE OrganizationId = lower(@msi_organization_id);
SELECT * FROM [insightsintegrations].[TenantServiceIntegrations];
UPDATE [insightsintegrations].[TenantServiceIntegrations]
SET OrganizationId = @as_organization_id
WHERE OrganizationId = @msi_organization_id;
ALTER TABLE [insightspermissions].[GroupRoles] NOCHECK CONSTRAINT FK_GroupRoles_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[GroupRoles];
UPDATE [insightspermissions].[GroupRoles]
ALTER TABLE [insightspermissions].[GroupRoles] CHECK CONSTRAINT FK_GroupRoles_Groups_GroupId_OrganizationId;
ALTER TABLE [insightspermissions].[TenantGroups] NOCHECK CONSTRAINT FK_TenantGroups_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[TenantGroups];
UPDATE [insightspermissions].[TenantGroups]
ALTER TABLE [insightspermissions].[TenantGroups] CHECK CONSTRAINT FK_TenantGroups_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[Groups];
UPDATE [insightspermissions].[Groups]
SELECT * FROM [insightspermissions].[Roles];
UPDATE [insightspermissions].[Roles]
SET Resource = @as_resource
WHERE Resource = @msi_resource;
SELECT * FROM [insightspermissions].[Tenants];
UPDATE [insightspermissions].[Tenants]
SELECT * FROM [insightspermissions].[Users];
UPDATE [insightspermissions].[Users]
SELECT * FROM [insightsprovisioning].[TenantInstances];
UPDATE [insightsprovisioning].[TenantInstances]
SELECT * FROM [read].[HASHKEYS];
UPDATE [read].[HASHKEYS]
