- 发行说明
- 在开始之前
- 管理访问权限
- 入门指南
- 集成
- 使用流程应用程序
- 创建应用程序
- 正在加载数据
- Transforming data
- 自定义仪表板
- 发布流程应用程序
- 应用程序模板
- 通知
- 其他资源
Process Mining
新增功能
Process Insights (preview)
The Process Insights dashboard provides an overview of anomalies and deviations, and shows how they impact your KPIs. Unusual patterns in process flows, such as unexpected handovers between team members, excessive delays in activities, or abnormal workload distribution are automatically identified. This allows you to quickly pinpoint areas that deviate from the standard process, enabling faster identification of inefficiencies, compliance risks, or potential operational issues.
Check out Process Insights (preview) for more information.
改进
阈值
- When a threshold is defined for a metric that is added as a KPI on a KPI values list chart and KPI trends list chart, the threshold is now automatically enabled for the chart.
- You can now create and edit thresholds when selecting a metric as a KPI for a KPI values list charts or a KPI trends list chart.
- Defined threshold values are now displayed when hovering over the threshold value in the KPI chart.
映射输入字段
The Autodetect option identifies field types in the input file and automatically applies the detected field types to the corresponding fields in the target table.
