Instalação do uipathctl rke2
Instale componentes da UiPath no Automation Suite no Linux.
Description​
Instale componentes da UiPath.
uipathctl rke2 install [flags]
Opções​
      --accept-license-agreement   Accept the license agreement
  -d, --debug                      Run in debug mode
  -h, --help                       help for install
  -i, --input string               Specify input json file
  -k, --install-kubernetes         Install Kubernetes and infrastructure modules
  -j, --join-node string           Type of node to be joined to an existing cluster
      --kubeconfig string          Specify path to the kubeconfig file
  -m, --machines string            Comma separated IP address / hostnames of all the machines
  -o, --output string              Specify output json file
      --region string              Specify region label value
  -r, --restore                    Setup Restore
      --skip-packages-install      Disable installation of package dependencies(helm, jq, etc.)
      --skip-pre-reqs              Skips pre-requisite checks during install
      --zone string                Specify zone label value
Opções herdadas de comandos pai​
  • Description​
  • Opções​
  • Opções herdadas de comandos pai​
Precisa de ajuda? Suporte
