Upload do Orchestrator de configuração do uipathctl
Carregue arquivos, extensões do NLog ou plug-ins de armazenamento seguro para o armazenamento.
Description​
Carregue arquivos, extensões nlog ou plug-ins de armazenamento seguros para o armazenamento
uipathctl config orchestrator upload [flags]
Exemplos​
# Upload files to storage
uipathctl config orchestrator upload --storage-directory /path/to/storage/directory
# Upload nlog extensions to storage
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directory
# Upload secure store plugins to storage
uipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directory
# Upload files to external storage
uipathctl config orchestrator upload --storage-directory /path/to/storage/directory --is-external-storage
# Upload nlog extensions to external storage
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directory --is-external-storage
# Upload secure store plugins to external storage
uipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directory --is-external-storage
Opções​
  -h, --help                                   help for upload
      --is-external-storage                    flag whether the storage is external
      --namespace string                       The namespace where UiPath Automation Suite is deployed (default "uipath")
      --nlog-extensions-directory string       location of the nlog extensions on the local disk
      --securestore-plugins-directory string   location of the securestore plugins on the local disk
      --storage-directory string               location of the storage directory on the local disk
Opções herdadas de comandos pai​
  • Description​
  • Exemplos​
  • Opções​
  • Opções herdadas de comandos pai​
Precisa de ajuda? Suporte
