uipathctl config add-host-admin
Adiciona o administrador de host com credenciais especificadas no Automation Suite.
Description​
Adicione um administrador do host e especifique as credenciais dele.
O comando utiliza como padrão o contexto atual no arquivo kubeconfig . Se o sinalizador --kubeconfig estiver definido, ele usará o arquivo kubeconfig especificado pelo sinalizador.
uipathctl config add-host-admin [flags]
Exemplos​
# Add host admin with the provided username and password in cluster
uipathctl config add-host-admin --username newadmin --password password
# Add host admin with the provided username, password and email in cluster
uipathctl config add-host-admin --username newadmin --email email --password password
# Add host admin with the provided username and password in the cluster identified by the current context in the kubeconfig file
uipathctl config add-host-admin --username newadmin --password password --kubeconfig cluster.kubeconfig
Opções​
  -e, --email string       host admin email
  -h, --help               help for add-host-admin
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
  -p, --password string    host admin password
  -u, --username string    host admin username
Opções herdadas de comandos pai​
  • Description​
  • Exemplos​
  • Opções​
  • Opções herdadas de comandos pai​
Precisa de ajuda? Suporte
