- 发行说明
- 在开始之前
- 管理访问权限
- 入门指南
- 集成
- 使用流程应用程序
- 创建应用程序
- 正在加载数据
- Transforming data
- 自定义仪表板
- 发布流程应用程序
- 应用程序模板
- Efficiency - Order process velocity
- 效率 - 供应商绩效
- 合规性 - 独立采购
- KPI
- Purchase to Pay - SAP input fields
- 通知
- 其他资源
Process Mining
The Order process velocity dashboard enables you to analyze and monitor the speed and efficiency of purchase order execution across the end-to-end Purchase to Pay process.
图表 | 描述 |
PR to GR milestones |
A bar chart that shows the time intervals and milestones from the creation of the Purchase requisition (PR) to the completion of a Goods receipt (GR). The PR to GR milestones chart allows you to track the flow, timing, and efficiency of the end to end process from purchase requisition to goods delivery. |
Revision PO items analysis | A bar chart that provides information on the number and of changes made to purchase order (PO) items within the end-to-end process. |
Revision events analysis |
A bar chart that provides information on the number, type, and distribution of revision (change) events that occurred across PO items in the end-to-end process. The Revision event analysis chart allows you to analyze process instability and rework trends that reduce speed and impact the number of first time right PO items. |
趋势 | The graph on the Trend chart shows the values of the selected metric over time, based on the Purchase order creation date. |
