- Premiers pas avec Test Suite
- Studio
- Test suite - Studio
- Vue d'ensemble (Overview)
- Activités et API de test
- Orchestrator
- Testing Robots
- Test Manager
- Démarrage
- Licensing Test Manager
- Guide de démarrage rapide
- Prérequis
- Assigning test cases to requirements
- Linking test cases in Studio to Test Manager
- Unlink automation
- Delete test cases
- Créer des scénarios de test
- Génération de tests optimisée par l'IA - Aperçu
- Clonage des cas de test
- Exporter des cas de test
- Cas de test automatisés
- Cas de test manuels
- Appliquer des filtres et des vues
- Ensembles de tests
- Exécution de tests
- Documents
- Rapports
- Exporter des données
- Opérations en bloc
- Résolution des problèmes
![](https://docs.uipath.com/_next/static/media/grid.05ebd128.png?w=3840&q=100)
- Platform: offers Test Manager as a service within your organization.
- Tester - Named User: allows you to use Test Manager.
In addition to the licenses above, Test Manager uses SAP Transport Units based on consumption, for Change impact analysis.
You need a Platform license to enable the Test Manager service within your organization.
To check if you have a Platform license that includes Test Manager:
- Navigate to the Admin tab.
- Sélectionnez Licences (Licenses).
- Go to the Robots & services tab.
If you already have a Platform license, that includes Test Manager, then you can perform the following steps for enabling Test Manager in your organization and tenant:
- Select the tenant for which you want to enable Test Manager.
- Accédez à Services.
- Select Add Services and then select Test Manager.
After you enable the Test Manager service on a tenant, you additionally need to allocate the Tester - Named User licenses to all users who should use Test Manager.
To allocate Tester - Named User licenses:
- Navigate to the Admin, and go to Licenses.
- Go to the Users tab.
- In the View Licenses section, check how many Tester - Named User licenses are available for your organization.
- Depending on how you want to allocate licenses (for user or for a group of users), perform the following steps:
- For users:
- Développez la section Attributions de licences aux utilisateurs (License Allocations to Users).
- For the desired user, select Edit license allocation.
- Select Tester - Named User.
- Select Save to confirm the license allocation.
- For a group of users:
- For the desired group, select Edit group allocation rule.
- For users:
To manage your organization's licenses, visit Allocating user licences.
UiPath Test Manager Connect licenses, provided by Planview, come bundled with your Test Manager platform license.
To use the cloud version of UiPath Test Manager Connect you need to request a cloud instance from the UiPath® sales team.
Lorsque vous analysez les transports via l’analyse de l’impact des modifications, vous consommez des unités de transport. Ces unités de transport sont proposées par packs de 100 unités.
Chaque analyse d’un transport unique va consommer une unité de transport. Par exemple, si vous achetez trois bundles d’unités de transport, vous pourrez analyser 300 transports uniques.
Lorsque vous analysez un transport qui a déjà été analysé, aucune unité de transport supplémentaire n’est consommée.
To manage your Transport units:
- Accédez à l'onglet Admin de votre organisation.
- Go to Consumables.
- View the usage of SAP Transport Units.
