- Vue d'ensemble (Overview)
- Pré-installation
- uipathctl prérequis
- uipathctl prereq create
- uipathctl prereq run
- Administration du cluster
- Sauvegarde et restauration
- instantané uipathctl
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Gestion des certificats
- Mettre à niveau
- Authentification
- Surveillance et alerte
- Résolution des problèmes
Non pris en charge par l'assistance
guide de référence uipathctl
Dernière mise à jour 29 avr. 2025
Exécute les vérifications des prérequis.
uipathctl prereq [flags]uipathctl prereq [flags]--excluded strings components to be excluded from execution, defaults to none
-h, --help help for prereq
--included strings components to be included in the execution, defaults to all--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
