guide de référence uipathctl
uipathctl config alerts update-email
Description​
Mettez à jour le destinataire des e-mails dans Alertmanager.
uipathctl config alerts update-email [flags]
Exemples​
        # Update existing receiver in alertmanager, Pass only those parameters which needs to be update along with mandatory parameter name.
        uipathctl config alerts update-email --name test --to "admin@example.com" --from "admin@example.com" --smtp "server.mycompany.com:443" --username admin --password "somepassword" --require-tls --ca-file "file path too rootCA" --cert-file "file path too server certificate" --key-file "file path too server key file"
Options​
--ca-file string     File path containing the CA certificate of the SMTP server. This parameter is optional if the CA is private
--cert-file string   File path containing the certificate of the SMTP server. This parameter is optional if the certificate is private
--from string        The sender's email address
  -h, --help               help for update-email
--key-file string    File path containing the private key of the certificate for the SMTP server. This parameter is required if the certificate is private
--name string        Name of the email configuration
--password string    SMTP authentication Password
--require-tls        Boolean flag to denote that TLS is enabled at the SMTP server (default true)
--send-resolved      Boolean flag to denote whether to send email on resolved alert (default true)
--smtp string        SMTP server URL or IP, including port
--to string          Receiver's email address
--username string    SMTP authentication Username
Options héritées des commandes parent​
  • Description​
  • Exemples​
  • Options​
  • Options héritées des commandes parent​
