- Vue d'ensemble (Overview)
- Pré-installation
- Administration du cluster
- Sauvegarde et restauration
- instantané uipathctl
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Gestion des certificats
- Mettre à niveau
- Authentification
- Surveillance et alerte
- Résolution des problèmes
Non pris en charge par l'assistance
guide de référence uipathctl
Dernière mise à jour 29 avr. 2025
--excluded strings components to be excluded from execution, defaults to none
-h, --help help for health
--included strings components to be included in the execution, defaults to all
-o, --output output output format. one of [json,yaml,text,junit] (default text)--excluded strings components to be excluded from execution, defaults to none
-o, --output output output format. one of [json,yaml,text,junit] (default text)--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
