- Vue d'ensemble (Overview)
- Pré-installation
- Administration du cluster
- Sauvegarde et restauration
- instantané uipathctl
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Gestion des certificats
- Mettre à niveau
- Authentification
- uipathctl sso
- uipathctl sso générer-connecteur
- uipathctl sso generate-overlays
- uipathctl sso generate-rbac
- uipathctl identity enable-basic-auth
- Surveillance et alerte
- Résolution des problèmes
Non pris en charge par l'assistance
guide de référence uipathctl
Dernière mise à jour 29 avr. 2025
Générez les couches Kustomize pour le déploiement SSO de la structure.
uipathctl sso generate-overlays [flags]uipathctl sso generate-overlays [flags]
Generate the overlays for a HA deployment of both ArgoCD and Dex, loading RBAC from a file
uipathctl sso generate-overlays --argocd-base ha --dex-base ha --argocd-url <https://argocd.local:30001> --rbac-file test-policies.csv --connector-file connector.yaml --dex-url <https://dex.local:32000> --kustomize-root ./hack/test/sso/kustomize
--argocd-base string ArgoCD kustomize base directory to use
--argocd-url string The externally accessible URL for ArgoCD (must include port if not standard for protocol)
--connector-file string Path to the Dex Connector's configuration file
--dex-base string Dex base kustomization to use
--dex-url string The externally accessible URL for Dex
--dex-use-https Optionally use https for Dex
-h, --help help for generate-overlays
--kustomize-root string Kustomize root directory
--rbac-file string Optional file to load the RBAC config for ArgoCD from (Overwrites policy.csv in the argocd-rbac-cm ConfigMap)--argocd-base string ArgoCD kustomize base directory to use
--rbac-file string Optional file to load the RBAC config for ArgoCD from (Overwrites policy.csv in the argocd-rbac-cm ConfigMap)--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
