- Vue d'ensemble (Overview)
- Pré-installation
- Administration du cluster
- Sauvegarde et restauration
- instantané uipathctl
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Gestion des certificats
- Mettre à niveau
- Authentification
- Surveillance et alerte
- Configuration uipathctl
- alertes de configuration uipathctl
- uipathctl - configuration des alertes - ajouter une adresse e-mail
- Ressource uipathctl
- rapport de ressource uipathctl
- Résolution des problèmes
Non pris en charge par l'assistance
guide de référence uipathctl
Dernière mise à jour 29 avr. 2025
Ajouter un récepteur d'e-mail pour Alertmanager.
uipathctl config alerts add-email [flags]uipathctl config alerts add-email [flags]# Adds new email receiver based on parameters passed in command
uipathctl config alerts add-email --name test --to "admin@example.com" --from "admin@example.com" --smtp "server.mycompany.com:443" --username admin --password "somepassword" --require-tls --ca-file "file path too rootCA" --cert-file "file path too server certificate" --key-file "file path too server key file"
--ASEA Boolean flag to denote whether the cluster is ASEA or not
--ca-file string File path containing the CA certificate of the SMTP server. This parameter is optional if the CA is private
--cert-file string File path containing the certificate of the SMTP server. This parameter is optional if the certificate is private
--from string The sender's email address
-h, --help help for add-email
--key-file string File path containing the private key of the certificate for the SMTP server. This parameter is required if the certificate is private
--name string Name of the email configuration
--password string SMTP authentication Password
--require-tls Boolean flag to denote that TLS is enabled at the SMTP server (default true)
--send-resolved Boolean flag to denote whether to send email on resolved alert (default true)
--smtp string SMTP server URL or IP, including port
--to string Receiver's email address
--username string SMTP authentication Username --ASEA Boolean flag to denote whether the cluster is ASEA or not
--username string SMTP authentication Username--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s) --context string name of the kubeconfig context to use
