uipathctl-Referenzhandbuch
uipathctl snapshot backup enable
Beschreibung
Aktivieren Sie die regelmäßige Momentaufnahmesicherung des Clusters.
uipathctl snapshot backup enable [flags]
Optionen
  -h, --help               help for enable
  -p, --prefix string      This will prefix the names of all the snapshot backups with the given string.
                       This is only used if you wish to enable schedule backup.
                     The default value is snapshot
                        (default "snapshot")
  -r, --retention string   Retention policy in duration format Hh:Mm:Ss, for e.g 8h5m1s.
                       Default value of 168h.
                        (default "168h")
      --schedule string    Unix cron expression for schedule
                       this is only required if you wish to enable schedule backup.
                     Default value "*/45 * * * *" denotes every 45th minutes backup is triggered.
                        (default "*/45 * * * *")
                        (default "168h")
  • Beschreibung
  • Optionen
  • Von übergeordneten Befehlen geerbte Optionen
Verbinden
Benötigen Sie Hilfe? Support
