- Überblick
- Vor der Installation
- Clusterverwaltung
- uipathctl-Cluster
- uipathctl-Clusterwartung
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl-Version
- Sichern und Wiederherstellen
- uipathctl-Snapshot
- uipathctl-Snapshot-Sicherung
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Zertifikatverwaltung
- Aktualisierung
- Authentication
- Überwachung und Warnungen
- Fehlersuche und ‑behebung
uipathctl-Referenzhandbuch
Letzte Aktualisierung 24. Feb. 2026
Beschreibung
Fügen Sie den E-Mail-Empfänger für Alertmanager hinzu.
uipathctl config alerts add-email [flags]
Beispiel
# Adds new email receiver based on parameters passed in command
uipathctl config alerts add-email --name test --to "admin@example.com" --from "admin@example.com" --smtp "server.mycompany.com:443" --username admin --password "somepassword" --require-tls --ca-file "file path too rootCA" --cert-file "file path too server certificate" --key-file "file path too server key file"
Optionen
--ASEA Boolean flag to denote whether the cluster is ASEA or not
--ca-file string File path containing the CA certificate of the SMTP server. This parameter is optional if the CA is private
--cert-file string File path containing the certificate of the SMTP server. This parameter is optional if the certificate is private
--from string The sender's email address
-h, --help help for add-email
--key-file string File path containing the private key of the certificate for the SMTP server. This parameter is required if the certificate is private
--name string Name of the email configuration
--password string SMTP authentication Password
--require-tls Boolean flag to denote that TLS is enabled at the SMTP server (default true)
--send-resolved Boolean flag to denote whether to send email on resolved alert (default true)
--smtp string SMTP server URL or IP, including port
--to string Receiver's email address
--username string SMTP authentication Username
