uipathctl-Referenzhandbuch
Uipathctl-Gesundheitspaket
Beschreibung
Generieren Sie ein Supportpaket, mit dem Sie Probleme mit der Automation Suite beheben können.
uipathctl health bundle [PATH] [flags]
Beispiele
 Generate the bundle in the OS temporary directory
uipathctl health bundle input.json
 Generate the bundle in a specific directory
uipathctl health bundle input.json/cluster_config.json --output-dir /foo/bar
 Generate the bundle without additional health/prereq report
uipathctl health bundle input.json/cluster_config.json --skip-diagnose
Optionen
  -h, --help                help for bundle
  -p, --include-previous    If false, skips printing the logs for the previous instance of the container in a pod if it exists. (default true)
      --limit-bytes int     Maximum bytes of logs to return. Defaults to no limit.
      --output-dir string   path to output directory
      --since-time string   Only return logs after a specific date (RFC3339). Defaults to all logs.
      --skip-diagnose       skip additional health/prereq report
      --versions string     path to versions file
      --excluded strings    components to be excluded from execution, defaults to none
      --included strings    components to be included in the execution, defaults to all
  -o, --output output       output format. one of [json,yaml,text,junit] (default text)
  • Beschreibung
  • Beispiele
  • Optionen
  • Von übergeordneten Befehlen geerbte Optionen
Verbinden
Benötigen Sie Hilfe? Support
