Automation Suite
False
- 概述
- 要求
- 安装
- 先决条件检查
- 下载安装包
- uipathctl cluster
- uipathctl 集群维护
- uipathctl cluster migration
- uipathctl 集群升级
- uipathctl 配置
- uipathctl 配置警示
- uipathctl configalerts add-email
- uipathctl config argocd
- uipathctl 运行状况
- uipathctl 运行状况捆绑包
- uipathctl 运行状况检查
- uipathctl health diagnose
- uipathctl health test
- uipathctl 清单
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl 先决条件
- uipathctl prereq create
- uipathctl prereq run
- uipathctl 资源
- uipathctl 资源报告
- uipathctl 快照
- uipathctl 快照备份
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl 版本
- 安装后
- 迁移和升级
- 监控和警示
- 集群管理
- 特定于产品的配置
- 故障排除
上次更新日期 2024年4月19日
删除快照备份。
uipathctl snapshot delete (name | --all) [flags]
-a, --all Delete all the snapshots
-f, --force Forcibly delete the snapshot without confirmation
-h, --help help for delete
