Automation Suite
False
uipathctl manifest diff - Automation Suite 2023.10
徽标
上次更新日期 2023年11月22日
描述
加载作为参数提供的配置,并将其与集群中的实时配置进行比较。
如果不使用任何标志,则仅比较清单,而忽略集群范围内的配置和依赖项。
输出始终为 YAML。 默认情况下,路径中可用的 diff 命令与u (统一差异)、 -N(将缺少的文件视为空)和 --color (彩色输出)一起运行。 添加 --no-color 标志以禁用颜色输出。
uipathctl manifest diff PATH [flags]uipathctl manifest diff PATH [flags]
示例
# Diff manifest found in input.json
        uipathctl manifest diff input.json
        # Diff manifest found in input.json, using the configuration found in cluster.kubeconfig
        uipathctl manifest diff input.json --kubeconfig cluster.kubeconfig
        # Diff manifest found in input.json, including cluster wide configurations and dependencies
        uipathctl manifest diff input.json --include-dependencies --include-config
选项
-h, --help                   help for diff
--include-config         include cluster wide config in the diff
--include-dependencies   include dependencies in the diff
--no-color               disable color output  -h, --help                   help for diff
从父命令继承的选项
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • 描述
  • 示例
  • 选项
  • 从父命令继承的选项
徽标
获取您需要的帮助
徽标
了解 RPA - 自动化课程
徽标
UiPath Community 论坛
Uipath 白色徽标
信任与安全
© 2005-2023 UiPath. All rights reserved.
