Automation Suite
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Upgrading Automation Suite on EKS/AKS
- Step 2: Restoring the standalone Orchestrator database
- Step 5: Updating the Orchestrator connection strings
- B) Single tenant migration
Automation Suite on EKS/AKS Installation Guide
Last updated 2023年12月4日
Rotate exchanges the current SAML data with the future one.
The command defaults to the current context in the kubeconfig
file. If the --kubeconfig
flag is set, it uses the kubeconfig
file specified by the flag.
uipathctl config saml-certificates rotate [flags]
Examples
# Rotate the saml certificates from the cluster
uipathctl identity rotate-saml-certificates
# Rotate the saml certificates from the cluster identified by the current context in the kubeconfig file
uipathctl identity rotate-saml-certificates --kubeconfig cluster.kubeconfig
Options
-h, --help help for rotate
