Automation Suite
False
- 先决条件检查
- 下载安装包
- uipathctl cluster
- uipathctl 集群维护
- uipathctl cluster migration
- uipathctl 集群升级
- uipathctl 配置
- uipathctl 配置警示
- uipathctl configalerts add-email
- uipathctl config argocd
- uipathctl 运行状况
- uipathctl 运行状况捆绑包
- uipathctl 运行状况检查
- uipathctl health diagnose
- uipathctl health test
- uipathctl 清单
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl 先决条件
- uipathctl prereq create
- uipathctl prereq run
- uipathctl 资源
- uipathctl 资源报告
- uipathctl 快照
- uipathctl 快照备份
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl 版本
上次更新日期 2023年12月4日
描述
加载在 PATH 中找到的配置,并将其应用于集群。
该命令在集群的当前状态和所需状态之间执行差异,并将更改应用于集群。
当存在 --override
标志时,列表将覆盖在输入文件中找到的选择。 该标志与 --only
标志互斥。 当输入文件中存在 exclude_components
键时,列表中找到的组件将从已安装的组件中排除。 它的优先级高于所有其他标志,并且与其中任何标志都不互斥。
uipathctl manifest apply PATH [flags]
示例
# Apply the configuration found in input.json, using the versions found in versions.json
uipathctl manifest apply input.json --versions versions.json
# Apply the configuration and specify the kubeconfig file to use
uipathctl manifest apply input.json --kubeconfig cluster.kubeconfig --versions versions.json
# Simulate the apply command and print on stdout the result of the operation
uipathctl manifest apply --dry-run input.json
# Apply the configuration but skip the components installed directly by helm
uipathctl manifest apply --skip-helm input.json --versions versions.json
# Apply the configuration overriding the initial list of components
uipathctl manifest apply --override automation_hub,orchestrator --versions versions.json
选项
--continue-on-error if true, continue applying the manifest even if an error occurs
--dependencies-only if true, only dependencies will be applied
--dry-run if true, just print the result of the command, without applying it
--fail-on-version if true, fail if the version of the component is not found in the versions file
-h, --help help for apply
--no-wait if true, return immediately after the ArgoCD applications are created
--only strings optional exclusive list of components to apply
--override strings optional list to override the components enabled in input.json file
--skip-dependencies if true, dependencies will be skipped
--skip-helm if true, skip components installed directly by helm
从父命令继承的选项
