- 概述
- 要求
- 安装
- 安装后
- 迁移和升级
- 监控和警示
- 集群管理
- 特定于产品的配置
- 故障排除
新发布内容的本地化可能需要 1-2 周的时间才能完成。
AKS input.json 示例
input.json 文件的参考示例,包括必需参数和可选参数,其中包含为 AKS 上的 Automation Suite 启用的所有产品。
以下示例显示了启用了 AKS 上所有产品的input.json文件,以及 AKS 上 Automation Suite 的必需配置参数和可选配置参数。您可以将该示例用作参考,并根据环境要求进行更改。
请注意,UiPath™ 产品选择至少要求启用平台服务。 确保将 FQDN、主机名、用户名和密码以及 SQL 连接字符串替换为您自己的配置。
"kubernetes_distribution": "aks",
"install_type": "online",
"profile": "ha",
"registries": {
"docker": {
"url": "registry.uipath.com",
"username": "",
"password": ""
"helm": {
"username": "",
"password": ""
"fqdn": "automationsuite.mycompany.com",
"admin_username": "admin",
"admin_password": "<your-password>",
"fips_enabled_nodes": false,
"fabric": {
"redis": {
"license": "", // fabric.redis.license must not be specified when fabric.redis.{hostname, password, port} are specified
"ha":false,
"hostname": "redis-cache.mycompany.com",
"password": "<your-password>",
"port": 6380,
"tls": true
"external_object_storage": {
"enabled": true,
"create_bucket": true,
"storage_type": "azure",
"use_managed_identity": false,
"azure_fqdn_suffix": "core.windows.net",
"account_key": "<your-account-key>",
"use_workload_identity" : "",
"account_name": "as-storage-account",
// storage type s3 specific config:
"fqdn": "",
"port": "",
"region": "us-east-1",
"access_key": "",
"secret_key": "",
"use_instance_profile": true,
"bucket_name_prefix": "",
"bucket_name_suffix": ""
"infra": {
"docker_registry": {}
"ingress": {
"service_annotations": {
"service.beta.kubernetes.io/azure-load-balancer-internal": "false",
"service.beta.kubernetes.io/azure-load-balancer-ipv4": "<ip>"
"gateway_selector": {
"istio": "ingressgateway"
"istioMinProtocolVersion": "TLSV1_3",
"disable_presigned_url": false,
"tolerations": [],
"exclude_components": [],
"server_certificate": {
"tls_cert_file": "",
"tls_key_file": "",
"ca_cert_file": ""
"additional_ca_certs": "",
"registry_ca_cert": "",
"identity_certificate": {
"saml_current_service_cert_file": "",
"saml_current_service_cert_pass": "",
"saml_future_service_cert_file": "",
"saml_future_service_cert_pass": "",
"ldap_cert_authority_file": ""
"sql": {
"create_db": false,
"server_url": "",
"port": "",
"username": "",
"password": ""
"orchestrator": {
"enabled": true,
"bucket_name": "uipath-as-orchestrator"
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"processmining": {
"bucket_name": "uipath-as-processmining"
"enabled": true
"integrationservices": {
"enabled": true,
"bucket_name": "uipath-as-platform"
"insights": {
"enabled": true,
"enable_realtime_monitoring": false,
"automation_hub": {
"enabled": true,
"automation_ops": {
"enabled": true,
"aicenter": {
"enabled": true
"documentunderstanding": {
"enabled": true
"test_manager": {
"enabled": true,
"action_center": {
"enabled": true,
"apps": {
"enabled": true,
"asrobots": {
"packagecaching": true,
"packagecachefolder": "/uipath_asrobots_package_cache",
"enabled": true
"studioweb": {
"enabled": false
"dataservice": {
"enabled": true,
"bucket_name": "uipath-as-dataservice"
"storage_class": "managed-premium",
"storage_class_single_replica": "azurefile-csi",
"platform": {
"enabled": true
"telemetry_optout": false,
"pod_identity" : {
"enabled": true,
"aks_managed_identity_client_id": <client-id>
"proxy": {
"enabled": true,
"http_proxy": "<http://<PROXY-SERVER-IP>:<PROXY-PORT>",
"https_proxy": "<http://<PROXY-SERVER-IP>:<PROXY-PORT>",
"no_proxy": "paste list from Configuring the cluster section"
"snapshot": {
"enabled": true,
"aks_infra_resource_group": "MC_ci-asaks4002399_ci-asaks4002399_eastus",
"cloud_name": "AzurePublicCloud",
"resource_group": "ci-asaks4002399",
"auth_mode": "ServicePrincipal",
"subscription_id": "b65b0225-ce9b-4a79-9dd9-c00071d40d64",
"tenant_id": "d8353d2a-b153-4d17-8827-902c51f72357",
"account_name": "storaccid2547865",
"bucket_name": "uipath-backup",
"client_id": "1fbd7d95-5f8c-4f70-90a6-fdf20310d10e",
"client_secret": "----"
"sql_connection_string_template": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='<your-password>';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"sql_connection_string_template_jdbc": "jdbc:sqlserver://mssql.mycompany.com:1443;database=DB_NAME_PLACEHOLDER;user=sqladmin;password={<your-password>};encrypt=true;trustServerCertificate=true;loginTimeout=30;hostNameInCertificate=mssql.mycompany.com",
"sql_connection_string_template_odbc": "SERVER=mssql.mycompany.com,1443;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=sqladmin;PWD={<your-password>};Encrypt=yes;TrustServerCertificate=yes;Connection Timeout=30;hostNameInCertificate=mssql.mycompany.com",
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://sqladmin:<your-password>@mssql.mycompany.com:1443/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server",
"postgresql_connection_string_template_sqlalchemy_pyodbc": "postgresql+psycopg2://sa:<password>@135.235.240.165:5432/DB_NAME_PLACEHOLDER"
"profile": "ha",
"registries": {
"docker": {
"username": "",
"password": ""
"helm": {
"username": "",
"password": ""
"fabric": {
"redis": {
"ha":false,
"port": 6380,
"tls": true
"enabled": true,
"fqdn": "",
"port": "",
"access_key": "",
"secret_key": "",
"infra": {
"ingress": {
"tolerations": [],
"tls_key_file": "",
"ca_cert_file": ""
"sql": {
"create_db": false,
"server_url": "",
"port": "",
"username": "",
"password": ""
"orchestrator": {
"enabled": true,
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"processmining": {
"enabled": true
"enabled": true,
"insights": {
"enabled": true,
"automation_hub": {
"enabled": true,
"automation_ops": {
"enabled": true,
"aicenter": {
"enabled": true
"enabled": true
"test_manager": {
"enabled": true,
"action_center": {
"enabled": true,
"apps": {
"enabled": true,
"asrobots": {
"enabled": true
"studioweb": {
"enabled": false
"dataservice": {
"enabled": true,
"platform": {
"enabled": true
"pod_identity" : {
"enabled": true,
"proxy": {
"enabled": true,
"snapshot": {
"enabled": true,
