Automation Suite
False
- 先决条件检查
- 下载安装包
- uipathctl cluster
- uipathctl 集群维护
- uipathctl cluster migration
- uipathctl 集群升级
- uipathctl 配置
- uipathctl 配置警示
- uipathctl configalerts add-email
- uipathctl config argocd
- uipathctl 运行状况
- uipathctl 运行状况捆绑包
- uipathctl 运行状况检查
- uipathctl health diagnose
- uipathctl health test
- uipathctl 清单
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl 先决条件
- uipathctl prereq create
- uipathctl prereq run
- uipathctl 资源
- uipathctl 资源报告
- uipathctl 快照
- uipathctl 快照备份
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl 版本
上次更新日期 2023年12月4日
Enter a short description of your concept here (optional).
您的概念将从这里启航。
描述
轮换操作会将当前的令牌签名证书数据与未来的令牌签名证书数据交换。
该命令默认为 kubeconfig
文件中的当前上下文。 如果设置了 --kubeconfig
标志,则它使用该标志指定的 kubeconfig
文件。
uipathctl config token-signing-certificates rotate [flags]
示例
# Rotate the token signing certificates from the cluster
# Rotate the token signing certificates from the cluster identified by the current context in the kubeconfig file
uipathctl config token-signing-certificates rotate --kubeconfig cluster.kubeconfig
选项
-h, --help help for rotate
从父命令继承的选项
