Automation Suite
False
uipathctl prereq run - Automation Suite 2023.10
徽标
上次更新日期 2023 年 11 月 22 日
描述
运行先决条件检查,以验证安装能否成功。
uipathctl prereq run PATH [flags]uipathctl prereq run PATH [flags]
示例
# Runs all the prerequisite checks
        uipathctl prereq run input.json --versions versions.json
选项
-h, --help              help for run
--versions string   path to versions file  -h, --help              help for run
从父命令继承的选项
--excluded strings    components to be excluded from execution, defaults to none
--included strings    components to be included in the execution, defaults to all
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • 描述
  • 示例
  • 选项
  • 从父命令继承的选项
徽标
获取您需要的帮助
徽标
了解 RPA - 自动化课程
徽标
UiPath Community 论坛
Uipath 白色徽标
信任与安全
© 2005-2023 UiPath. All rights reserved.
