Automation Suite
False
- 概述
- 要求
- 安装
- 先决条件检查
- 下载安装包
- uipathctl cluster
- uipathctl 集群维护
- uipathctl cluster migration
- uipathctl 集群升级
- uipathctl 配置
- uipathctl 配置警示
- uipathctl configalerts add-email
- uipathctl config argocd
- uipathctl 运行状况
- uipathctl 运行状况捆绑包
- uipathctl 运行状况检查
- uipathctl health diagnose
- uipathctl health test
- uipathctl 清单
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl 先决条件
- uipathctl prereq create
- uipathctl prereq run
- uipathctl 资源
- uipathctl 资源报告
- uipathctl 快照
- uipathctl 快照备份
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl 版本
- 安装后
- 迁移和升级
- 监控和警示
- 集群管理
- 特定于产品的配置
- 故障排除
上次更新日期 2024年5月20日
-h, --help help for enable
-p, --prefix string This will prefix the names of all the snapshot backups with the given string.
This is only used if you wish to enable schedule backup.
The default value is snapshot
(default "snapshot")
-r, --retention string Retention policy in duration format Hh:Mm:Ss, for e.g 8h5m1s.
Default value of 168h.
(default "168h")
--schedule string Unix cron expression for schedule
this is only required if you wish to enable schedule backup.
Default value "*/45 * * * *" denotes every 45th minutes backup is triggered.
(default "*/45 * * * *")
(default "168h")
