Automation Suite
False
uipathctl 先决条件 - Automation Suite 2023.10
徽标
上次更新日期 2023年12月4日
uipathctl 先决条件
描述
运行先决条件检查。
uipathctl prereq [flags]uipathctl prereq [flags]
选项
--excluded strings   components to be excluded from execution, defaults to none
  -h, --help               help for prereq
--included strings   components to be included in the execution, defaults to all--excluded strings   components to be excluded from execution, defaults to none
从父命令继承的选项
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • 描述
  • 选项
  • 从父命令继承的选项
徽标
获取您需要的帮助
徽标
了解 RPA - 自动化课程
徽标
UiPath Community 论坛
Uipath 白色徽标
信任与安全
© 2005-2023 UiPath. All rights reserved.
